Polk RTA 8TL's
Polk_Denon
Polk_Denon Posts: 27
edited September 2020 in Speakers
I picked up a pair of these awhile back for cheap. One has a blown tweeter. Before I get a new tweeter for it, how do they sound with music? That would be the main use for them.
  • stevep
    stevep Posts: 364
    I have two pairs of RTA-8TL and think they over perform for their price point.
    The replacement tweeter for the TL version is the RD0-198 which is the factory sub for both the SL2500 and SL3000 tweeters.
  • Polk_Denon
    stevep wrote: »
    That's the model I was looking at for a replacement.
    Have you ever put them on a small stand to get them a little higher?
  • stevep
    stevep Posts: 364
    I've tilted them back using points but if you raise them make sure it's a solid base.
