GEEK PULSE X Infinity with Linear Power Supply (LPS) - Balanced Headphone Amplifier, Balanced DAC
geppy1
geppy1 Posts: 3,076
edited August 2020 in For Sale (FS) Classifieds
Selling a LH Labs Geek Pulse X infinity DAC/headphone amp with the hard to find LPS power supply. Works and looks great and comes in original boxes and packing with cables and the Apple remote See specs below Asking $695
I also have a Geek Pulse DAC/ headphone amp with wall wart power supply In original box
Asking $275
Pulse DAC Makes Excellence Accessible
The SIRE and DA VINCI aren’t just fantastic DACs, they’re perfect development platforms. Many of the key elements from our flagship products are also available in our more popularly priced products like Pulse DAC.
Dual Mono, Dual DAC Configuration (Pulse DAC X and Infinity)
Precision Passive components
3L Digital Buffer
FEMTO Clocks
SUPERB DIGITAL TO ANALOG CONVERSION
Single ESS9018K2M DAC in Pulse DAC
DUAL ESS9018K2M in Pulse DAC X and Infinity
32/384 PCM
Dual High-precision clocks (one for 44.1kHz PCM/2.8224 MHz DSD, second for 48 kHz PCM/3.072 MHz DSD)
FEMTO Clocks for vanishingly low jitter in Pulse Infinity
USEFUL CONNECTIVITY AND CONTROL
All Pulse units feature 5 digital inputs for compatibility with a wide range of sources
1 TOSlink (accept up to 24 bit/192 PCM)
2 Coaxial (accept up to 24 bit/192 kHz PCM
1 AES/EBU
1 USB (accepts up to 32 bit/ 384 kHz PCM, DSD64)
Excellent Headphone Amplifier
Headphone output configuration:
Balanced XLR 4 Pin Female Jack (Neutrik)
Single-end via 1/4″ TRS Headphone Jack
Headphone Balanced output voltage and impedance (Pulse DAC X and Infinity):
3.5V / 6V / 13.8V selectable
0.9 Ohm output impedance
dual mono headphone output amplifier (CAPS IN FRONT)
Headphone Single- ended output voltage and impedance (all models):
1.8V / 3V / 6.8V switchable
0.47 Ohm output impedance
  • geppy1
    geppy1 Posts: 3,076
    OK The price is now dropped to $250 for each item. In other words each DAC $250 Your choice and if you wan the big LPS power supply that can go with either DAC $250. Each DAC does come with a wall wart power supply
  • geppy1
    geppy1 Posts: 3,076
    Here is a better description of the situation
    Al items work as they should and come in original boxes with power cords or power supplies. . Your choice of two DACS and either can be mated with a LPS power supply FYI both DACS come with wall wart power supply The LPS is just an upgrade.
    LH Labs Geek Pulse X infinity DAC/headphone amp with wall wart power supply Asking $250 See info below
    LH Labs Geek Pulse DAC/ headphone amp with wall wart power supply $250
    Hard to find LPS power supply. This can be used with either unit above in place of the wall wart power supply. Asking $250
    3L Digital Buffer
    FEMTO Clocks
    32/384 PCM
    1 AES/EBU
  • KrE8oR
    KrE8oR Posts: 1
    Hey just wondering if you're still selling these?
    Lemme know keen to get on the Pulse X infinity if its still around!!
  • geppy1
    geppy1 Posts: 3,076
    Hi I have the LPS power supply and a regular Geek Pulse in the box
