Computer help please
What I would like to do is use all 3 of my HD and 1 SSD (which is also boot drive) and use them in conjunction with my new laptop to be used as the real boot and main "brains" can I just buy a slim tower to power and house the drives? I want to get rid of the big tower desktop (it's also getting older and slower).
  • mrbiron
    mrbiron Posts: 5,721
    Sounds to me like you should buy 1 large external HD, load it up with everything you have, connect it to your laptop/network, and dump the rest. 10TB WD go for ~$200US and are frequently on sale.
    Just my $0.02...
  • Willow
    Willow Posts: 11,246
    The reason I like having a couple of drives is to protect me from disk failure. I have a drive of all my stuff, one for pics and videos then a backup drive for all.
    mhardy6647 Posts: 35,200
    edited September 2020
    Get an NAS (or is that "a NAS"? ... or just "NAS").
    Network attached storage. Populate with 2 or 4 drives and have some fault-resistant storage on line.
    I have a small one now (graciously passed along to me by one of the local hifi gurus) -- two 2 TB drives -- and I've already decided to move to a bigger/more serious system soon. I love the danged thing.
    This is the one I've got my eye on (and, courtesy of my kind and much-beloved son, I've already got two 6 TB drives to populate it with)
    https://www.newegg.com/synology-ds220/p/N82E16822108743
    The four drive NAS gives one maximum bang in terms of fault-resistant on-line storage, but will be commensurately pricier. :)
    Alternatively you can buy little interface boxes that will hold an HDD (or SSD) and inteface with a USB (2 or 3) port to keep (or get) a "surplus" disk online as and if desired.
    I have one of these, too -- mostly used to clone laptop HDDs when I "upgrade" to an SSD. :)
    This is the one I have, FWIW (acquired from Newegg years ago):
    https://www.amazon.com/Rosewill-Armer-RX202-Enclosure-Indication/dp/B011LZY56W
  • mrbiron
    Willow wrote: »
    Then make those drives your backups. Your security drives in case the new storage solution fails.
    What size are the other 4 HDDs? How much space do you need/want?
  • If you don’t know already about them, look into RAID arrays. You can set up most (or all?) NAS as RAID. Basically you use multiple HDDs and it can mirror data in a variety of ways so that if one drive fails you lose no data. You just pop in a new drive and it repopulates it just like the old drive was. Redundancy.
  • afterburnt
    afterburnt Posts: 7,892
    What they said about the NAS and I would add that you should get a portable drive of the same capacity update as needed and leave it in your car or in my case in my backpack that goes everywhere with me.
  • Retire the old HD's and get new ones. Whether a NAS or external drives, start with fresh drives so they are less likely to fail. You will need to address backup methodology and software to cover it. Also need to understand the level of fault tolerance versus the cost of the backup solution. You have the cheapest solution (an external USB drive), to a NAS, and then cloud storage for off-site security.
    I personally use a NAS myself (Synology DS218+ with dual 8TB drives) plus have a WD drive for occasional backup. It's manual, but OK for the files I care about.
    The NAS is my media "server" for streaming to Intel NUC media players.
  • muncybob
    muncybob Posts: 3,262
    I wish I had done backup drives...my pc is in the shop and fingers crossed they can save files for me. Won't be that lazy(ignorant) again!
    Yep, my name really is Bob.
  • Storing things in the cloud is a great option. If catastrophe strikes your home then your files are safe. Financial records, photos, novels, etc. Many types of irreplaceable files. Downside is cost, but you get what you pay for.
    Know a semi-pro photographer that uses cloud backup. It's a must have for him. Plus side is the files are available when he travels and doesn't have his machine handy.
  • Agreed, but I wouldn't trust either of those companies with my data. Maybe Microsoft since it's integrated with Office. Know many people that use Backblaze or Carbonite.
    Yeah -- not a cloud fan.
    I do use a photo hosting service (heck, I even pay for it) -- but only for (my) convenience.
    I wouldn't leave anything important "in the cloud" without local backups, given that I have absolutely no control over "the cloud" nor the companies that offer the services.
    50124545971_c7101337de_h.jpgDSC_0915 (2) by Mark Hardy, on Flickr
    Typical old guy attitude, I know, but I have (predictably) old-fashioned views about ownership.
    I'm a fan.
  • muncybob
    Was that the metoer that did in the dinosaurs?
    muncybob wrote: »
