Display issue changed
BlueFox
BlueFox Posts: 15,250
It used to be if you read a post then the post would show as unread as long as you were logged in . Tonight that appears to be fixed. Good job and thank you.
    audioluvr Posts: 5,982
    Right!
    mhardy6647 Posts: 35,201
    I've always found the "new posts" algorithm to be a little iffy since Vanilla came into town.
    I consider it part of Vanilla's quirky charm -- you know, sort of like Babs Streisand's schnozz.
    B)
  • BlueFox
    It is broken again. Those clowns can't do anything right.
