We've joined the basement flood club :(
    xschop Posts: 5,117
    Hang in there. Glad you got it under control. I went thru similar last year. A PEX line along perimeter of concrete slab developed a "nick" over time (5.1 quake exacerbated) and didn't detect for awhile until wall was soaked. The only way to mitigate was chisel out treated basplate. I was extremely lucky enough to have the exact amount protruding from foundation that I could install a Sharkbite coupler. After a week of drying, I applied 2 layers of Kilz and added some lye for good measure.
    mhardy6647 Posts: 34,959
    Set some traps last night at the top and bottom of the wall (i.e., attic & basement).
    Woke this morning to find one mouse that had been transformed to, shall we say, an erstwhile mouse. B)
    Now, that may not have been the smoking gun -- but at least it's a start!
    There is still a very slow drip (1/2 inch of water in a 5 gal bucket overnight) but places I can see are dried out and the plumber'll be back next week. I feel like we're stable for now.
    Actually not too worried about mold per se. Worst case, I think, would be one 16 inch "cell" (section of wall between two studs) full of soaked insulation. We shall see.
    VR3 Posts: 29,415
    While this wouldnt help with radiant heating applications -
    I have been using a Flo by Moen device for over a year and within a couple hours it detects, notifies, and will shut off water if it detects a drip in a faucet. If it detects higher than normal GPM (burst pipe) or any abnormal water usage it notifies you within minutes of the event starting. I cant recommend this device enough for protecting your home from water leaks (plus it monitors water usage and such)
  • charley96
    charley96 Posts: 341
    Good idea on the detector. I always shut my water off whenever I'm out of town for a few days. Girlfriend had a neighbor who came home to an $800 water bill when he was gone for a month. He had a mess when a pipe broke.
    VR3 Posts: 29,415
    Absolutely, the device allows you to shut off your water anywhere in the world with the touch of a button on your phone (on top of the monitoring for leaks and monitoring water usage) + it lets you compare your actual water usage to your utilities company claim to what you used
    heh -- not my phone. :|
  • motorstereo
    motorstereo Posts: 2,325
    Glad to hear you have the leak under control; but still what an unnecessary pita. One of my winter projects was to tear out all my aging copper pipes and shut offs and replace them with sharkbite fittings and pex. After reading about your catastrophe I'm putting that project on hold.
  • Milito
    Milito Posts: 2,003
    Plumbing leaks aren't fun, sorry to hear about this.
    We had small one on the hot water pipe in our foundation that ran under the floor in our MBR closet. The only reason we discovered it was the floor tile in the closet was warm when we walked on it.
  • kevhed72
    kevhed72 Posts: 5,139
    edited August 2020
    I have joined the club!!!! Wooo-heeee! Been up since 5 cleaning up water in basement and vacuuming out carpet a hundred times. GD blue plastic water line coming into the basement sprung a leak. Freezing or no freezing....this stuff should be banned. I know numerous people down here who have had issues with this sh#t pipe. Plumber coming tomorrow....stay tuned!
    pitdogg2 Posts: 26,993
    edited August 2020
    PEX? Or is that main cold water coming into house? If they use Plastic main here it's thick black cold water pipe.
  • kevhed72
    Its the main water line coming into the house but its not pex. Its pretty flexible and inexpensive, which is great for builders and sh#t for homeowners.
    kevhed72 wrote: »
    :( Sorry to hear. Needless to say, I'm empathetic.
    Hoping our plumber will get by tomorrow, too.
    Things are mostly dried out -- still a very, very slow drip downstairs... which I am hoping will aid diagnosis. :|
  • kevhed72
    kevhed72 wrote: »
    Good luck....hopefully you still have use of the water in the meantime. We had to result to "hillbilly showers" as my kids called them. Dad runs out to the street with pliers, calls child on cell to get in shower, then turn on water at the street. Repeat process to turn off shower and for multiple showers. Makes you realize how good life really is....
  • kevhed72
    edited August 2020
    The area where the supply line comes into the house is getting 2 of these....Ill happily add another removable panel in the wall to add these. 12 bucks you cant go wrong...
    edited August 2020
    kevhed72 wrote: »
    kevhed72 wrote: »
    Yeah, it's jarring to suddenly find oneself living under Third World developing world conditions! :(
    Hope you remember to turn on the water before you're getting undressed for the shower! ;)
    We are exceptionally lucky with the construction of this house. Right now, we have all of the valves closed on the heating zones, but the domestic hot water circuit is still operating.
    All of our hot and cold water lines have individual shutoffs on two manifolds in the basement. When we discovered the leak, I shut 'em all off (EDIT: all of 'em that go to the second floor, that is). After the leak was markedly slowed, I have turned lines back on, piecemeal, to see if any of the domestic water lines could (also?) be involved. At the moment, everything to our bathroom is turned back on (except the tub hot and cold supplies -- since we never use the tub!). All of the supply lines to the "guest bathroom" are still off -- except the terlit (because, well, you know... you can't have too many terlits on-line!). :)
    EDIT^2: I realize this wouldn't help in your case, though, since the issue's where the line comes in to the house :(
    Here's a photo of Ground Zero :) I just sent this to the plumba as a gentle 'ping', since I think he's back from Wyoming as of yesterday. ;)
    EDIT: The mousetrap is partly visible to the right side of the beam. :) There have been no further executions - for better or for worse - since the initial one the night of the event :|
    Hope your situations works out well, and quickly!
    Post edited by mhardy6647 on
  • mrbiron
    mrbiron Posts: 5,720
    How did you get Ray Charles to do all that wiring for you and keep it all in one spot?!?
  • Emlyn
    Emlyn Posts: 4,670
    Many years ago I had mice chew the plastic parts out of the bottom of a dishwasher, including the hose that let water out of the machine. I only noticed it because I turned the dishwasher on one day and heard water cascading downstairs when the dishwasher reached its rinse cycle. Mice gnaw on whatever is available and they follow wiring and pipes through a building, but they also need water. They'll get at water however they can including chewing up plastic pipes.
    It's also possible, I suppose, that the radiant heating PEX pipes got worn over time by foot traffic on the floor above. Unlikely, but possible.
    mrbiron wrote: »
    I am sure it was the color-coding. B)
  • charley96
    I'm glad i re-plumbed with heavy grade copper a few years back.
  • aprazer402
    aprazer402 Posts: 3,376
    I like the way this is laid out. I'm not a plumber.
    My uncle was a union plumber for 44 years (all commercial big new building jobs).
    He retired in the late1980's, he passed about 12 years ago.
    He commented to me several times how he hated seeing these new plastic pipes. Even though he never used any of it. He was just old, old school. He worked with lead, galvanized and copper. He was tough, working with galvanized, cutting and threading it.
    Steam fitting and plumbing is hard work.
    Being union, he was well paid WHEN work was plentiful. Which lasted until around 1981 when things slowed way down. I remember a younger union plumber with less seniority and a young family having to leave Nebr. in 1981 to work as a plumber on a job in NH (just a coincidence) for a few months to make ends meet.
    Our house in MA had all copper plumbing -- but it was built in the early 1970s, when copper had gotten expensive, so it was all thin-walled pipe (I guess the stuff used for heating).
    Years of hard water, wear and tear were exacerbated when we moved in (1991) and added a water softener & pH neutralizer. We got pinhole leaks everywhere, piecemeal. Ended up replacing a lot of plumbing in that house, over the years.
    That house also had aluminum wiring :p
  • aprazer402
    edited August 2020
    I have seen several homes with aluminum wiring. In fact a friend that is an Elec. Engineer whose home was built in 1971 had aluminum wiring. He lived in it for close to 25 years before selling it. He said he just made sure all the connections were tight. He really didn't fear it. I would though! :)
    edited August 2020
    aprazer402 wrote: »
    Yup, it's not a disaster per se-- even though it could be. Whenever we had "to the studs" remodeling done, we had the wiring replaced. That's why I call the MA house "House 3.2" -- it went through two fairly major renos. :) Our electrician also installed copper pigtails (for lack of a better word) in all the switch and outlet boxes, and at the fixtures. There's a code-accepted "repair" (or at least there was, in the 1990s) that involved (IIRC) a crimped connection and sort of oxidation-resistant sealant.
    House 3.2
    (I'll have to dig out a photo of ver 3.0 sometime...)
  • aprazer402
    edited August 2020
    Nice! Very traditional two story colonial (sans attic dormers). Your new home has a similar style. I see a chimney on the garage roof, is there a fireplace in the breezeway? I see skylights in that area too. The pig tails are known as AlumiConn connectors.
    The back side, more skylights! and a little family room addition?
    edited August 2020
    aprazer402 wrote: »
    Yeah -- now that you mention it... AlumiConn.
    Mrs. H likes colonials, and - when push comes to shove - so do I. :)
    We designed House 4.0 to resemble 3.2 :) -- but the floor plan is completely different. It's also a little smaller, which is a mixed blessing.
    3.2 had a big family room between garage & main house, which was quite nice. As purchased, the room was paneled with knotty pine stained dark, dark brown. Opressively dark. :/
    3.2 also had what had been a 3 season porch on the back which had been enlarged and enclosed (albeit ham-fistedly) by the previous (original) owner into a game room of sorts. We had both of those rooms gutted and redone (3.1)
    10839612055_1fcaa740a3_b.jpgDSC_7739 by Mark Hardy, on Flickr
    10839611305_562300b733_b.jpgDSC_7639 by Mark Hardy, on Flickr
    These photos are from move-out day, July 2013 :|
    OK -- the mauve was fairly fashionable when we put it in! :p
    3.2 needed the skylights (it had 5 when we got it, we added one to each bathroom when the latter were redone in the mid-90s: 3.2) -- it was, as you can see, nestled in the trees.
  • aprazer402
    Your first front photo has a tree right where I was thinking a door should be going into the family room that I had pegged as a breezeway between house and garage. Did the entire house have hot water baseboard heating or is it electric heat hard to tell? I see it in all your interior room photos. Looks like it was a very nice home for you.
  • invalid
    invalid Posts: 1,454
    aprazer402 wrote: »
    The problem with the aluminum branch circuit wiring done in 1970,'s was a common problem called cold creep, the aluminum would heat up differently than the fasteners and when it cooled down you would have a loose connection. Most new houses nowadays use aluminum wire for the service feed and there isn't a problem with it as long as it's tighten to spec.
    aprazer402 wrote: »
    All baseboard.
    The back room had an electric baseboard :o when we bought it. When we redid it, we added a zone of hot water baseboard heat.
    No exterior door to the family room. There was a slider to the deck off the erstwhile porch. The FR had a door into the garage to give, ultimately, access to the outside world.
