these tube pre's any good? Link
faster100
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14974&item=5748456790&rd=1&ssPageName=WDVW
looking for a tube pre, budget minded... audio experience is my first choice.. found this one today though... they offer another one also...
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
I personally would give it a try if I needed one. His price is pretty close to the cost of parts. I kinda wish I needed one now.
are the tubes popular? or easy to get, and whats a line stage mean? I mean what should i be looking for in a new currently made tube pre amp? ThanksMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I'll add my 2 cents, FWIW. First, I am a proponent of purchasing Chinese audio equipment because the cost and value is quite compelling. I have a modded Chinese tube CD player that is just as good, if not better than the modded Jolida 100, IMO, based on an A/B test, and it was half the cost. Build quality is excellent, as well (18 lb. CD player!). The downside is that you don't get a warranty.
Three things to keep in mind --
1.) make sure the unit is equipped run with US voltage
2.) double check the shipping costs (sometimes they can be quite high)
3.) change out the cheap Chinese tubes immediately and be prepared to do some mods at some point to get the best possible SQ
Also, check out www.nysound.com for more options.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the info guys...... will ask shipping charges alsoMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Just a note of interest, the Jolida is basically a Chinese made cdp with final assembly here in Maryland.Political Correctness'.........defined
