Making a blade/blade interconnect cable
muncybob
I would like to have a better cable made for the 2Bs....where can you get the end pieces?
Yep, my name really is Bob.
You would be better served to switch to the Neutrik speakon connection. You can get better cables on those as you have more room for bigger cable.
The blade/ Blade ends are tiny and it's hard to get 12 gauge in there to solder. Plus the after market ends are not the best made.
https://www.google.com/search?ie=UTF-8&source=android-browser&q=Cinch+jones+plugs+p-302 -
I agree with Ivan, go with the Neutrik SpeakOn. Be sure to get the 4 pole heavy duty air tight version. Somewhere in here I've posted the ones to get, if you want to look.Political Correctness'.........defined
President of Club Polk -
So I need these?
https://www.parts-express.com/neutrik-nl4mp-speakon-connector-4-pole-panel-mount--092-052
Does it matter which connector is used on the cable?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
https://www.parts-express.com/neutrik-nlt4mp-bag-speakon-stx-4-pole-male-chassis-connector-black-chrome-metal-housing--092-340#!
https://www.parts-express.com/neutrik-nlt4fx-bag-speakon-stx-4-pole-female-cable-connector-black-chrome-metal-housing--092-336
These are what we used^^^^
I used these ends at the speaker and dreadnought. They (for me) worked better in cable management but are a pita to work with.
https://www.parts-express.com/neutrik-nl4frx-speakon-spx-right-angle-cable-connector-4p--092-192?gclid=EAIaIQobChMI2LPz-eiB6wIVyEXVCh3rvgUlEAQYASABEgKoHPD_BwE -
So I need these?
Yes, that's the one I use along with the NLT4FX-BAG.
Not really, but be sure to connect + to + and - to -.Political Correctness'.........defined
