1984 m7's with mw6500?
I picked up a pair of m7's that are mint, like they never had been out of the box. Not a scratch, grill covers tight and perfectly clean. I went to epoxy the magnets and the drivers are 6500 from 84. No stamp on the sticker just hand written date and initials.
Do all 7's have mw6500?i thought they would be 6502.
BTW the magnets are not centered at all way off by as much as an 1/8 but drivers move perfectly.
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
  • Gardenstater
    Gardenstater Posts: 4,781
    edited July 2020
    What's the month? The earliest schematic we have is from 11/26/84 and that shows the MW6502, so if we have your month we'd have a pretty good idea of when they switched over from MW6500's. My 79's have MW6500 and Danish Peerless tweeters. The hole in the magnet is much larger than the O.D. of the voice coil so they can slip quite a bit and still not rub on the voice coil. The clearance of the OD to the outer pole piece and the ID to the inner pole piece is not a lot. You may be lucky for now, but you might find that it scrapes at some times, perhaps on difficult bass sections of music. You might want to just put a few short beads of adhesive that would be easily removable with an xacto knife, just to make sure they don't slip any more than they already have. You may have to realign some time in the future and being able to remove the adhesive will be advantageous. I don't think I'd use epoxy in your case because it would be very difficult to remove. I'd use some sort of construction adhesive. I like Gorilla Max Strength Clear, but make the beads very short, like 1/2" and I'd only do 3 of them per side of the magnet.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • wispolkboy
    wispolkboy Posts: 150
    Thanks for your reply!
    I pulled the drive again and upon closer evaluation of the date, '82
    I epoxied the driver on each side.
  • Gardenstater
    If you get a chance snap some photos and post em. People love seeing minty examples. What tweeters and crossover schematic do you have?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • wispolkboy
  • Gardenstater
    Well they certainly do look nice! Mine are 190xx serials and have the same crossovers as yours. Are these real walnut veneer? Sometimes its hard to tell if vinyl or not, they did such a good job. Mine have different grills and pegs, with the Polk Audio on the grill and grill covers entire front. Those are attractive (custom?) stands. Are they tippy at all? Have fun doing the rest of the mods and enjoying the improvements to come.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • wispolkboy
    stands from amazon, $60, a little tippy, thinking of making a bigger base or making the height a bit shorter.
    not real veneer, just vinyl.
    I have an old NAD 7155 but i think it needs some tlc on it. it was powering some sda's 2b. switched them for the 7's
  • Gardenstater
    My stands are 24" tall also and I find that height is perfect for my listening position, putting the tweeters right about at ear height. Honestly though I think those stands are not stable enough for these speakers and it doesn't really look like they are fillable with sand/lead shot. My stands have 2 16" x 16" concrete blocks as the base (36lbs ea) and a steel column that is filled with sand/lead shot.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • wispolkboy
    I like the idea of increasing the weight.... I'm thinking about a 1/4 steel plate on the bottom.... Cut to the shape and painted... Thanks for the tip
  • Gardenstater
    I think I'd go with 1/2" steel. A 16" x 16" piece of that'd be about 36 lbs.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • wispolkboy
    I think I can cut 1/4" to the shape. 1/2 would be difficult.
    And 1/4 on the very bottom would give a very low center of gravity.
    Better than what I have now
  • Gardenstater
    edited August 2020
    OK good luck. If you don't increase the dimensions of the base you won't get that much more stability, even though the increased weight certainly helps. 16" works great for me. If you really like the way the base looks now (rounded 3/4" MDF?), just make a bigger one and put one or two 1/4" steel plates underneath it with Gorilla Super Strength const. adhesive or the like, and maybe 4 screws.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,770
    edited August 2020
    An even better idea, buy the 4 post stands from www.skylanstands.com
  • wispolkboy
    Thanks for the site.... however I really don't like the look of those. (or price, lol)
    I was thinking the same as far as how to add the plates to the base.
    thanks for all your coments!
