Cable management. Which cables to strap together?
I figure power cables are ok to velcro together but what else can I sling up without deleterious effect?
    mhardy6647 Posts: 35,104
    well, I would posit that any shielded cables (e.g., XLRs, but you may have others) ought to be OK -- that's why they're shielded! :)
    Do you know what a snake is?
    That's the way signals travel around in performance venues -- and in the recording studio B)
    Otherwise, crossing at right angles for anything carrying AC (and the music signal is AC, of course) and/or as far apart as possible is a best practice).
    Practically speaking? Why not try and see if you can detect any difference?
  • SIHAB
    SIHAB Posts: 5,471
    I'll be following this thread.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited August 2020
    I'm tangled up at the moment
    pitdogg2 Posts: 27,127
    Jaylunb1 reported
