Henry Rollins Vinyl tips.
One of the drawbacks of the thicker pressings is static. Vinyl is an insulator, so any static charge that gets introduced on a thicker record tends to stay there unless mitigated in some way. Of course poly-lined sleeves and carbon fiber brushes help with this, or the old Zerostat, but I like to clean all new-to-me records with a cleaning solution that includes a quat for its anti-static properties."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
What cleaning solution recipe are you currently using, Jody?
I forget, do we have a vinyl thread here? Maybe on one of the RCM threads?I disabled signatures. -
Hey Scott, below is what I use. I know a lot of folks use ready-made cleaning solutions, so to-each-their-own.
Ingredients:- Triton X-100 (standard grade...I don't know how many grades exist)
- Hepastat256 (this is the 'Quat', and this product's concentration is what works for my proportions)
- 99% Isopropyl alcohol
- Distilled water
I have a Knosti Disco Anti-stat, and the tank holds about 500ml. I use a large Pyrex measuring cup to mix the solution; the size of the measuring cup holds 500ml / 16 fluid oz / 1 Pint / 2 Cups. A smaller measuring cup sized for about 2 fluid oz / 50-75ml is also needed. And finally, a pipette of 2ml is needed - available at hobby stores and elsewhere.
In the big measuring cup, add the following:- 25ml of isopropyl alcohol; measure in the smaller measuring cup, and then pour into the large measuring cup.
- 0.75ml of Triton using the pipette; it dissolves quicker in the alcohol than in water, so that's why we add it here; stir it around a bit. Rinse the pipette inside and out - suck water into it and squeeze out several times.
- 0.25ml of Hepastat256, again using the pipette.
- Fill the rest of the measuring cup up to the 500ml mark with distilled water, and stir.
This yields a solution of 5% isopropyl alcohol, 0.15% Triton X-100, and 0.05% Quat, which is a good concentration for record cleaners like the Knosti, Spin Clean, and others of that design. For an ultrasonic cleaner, use less Triton (0.25ml), which is the same amount as the Quat...again this would be for a 500ml batch of cleaning solution. Obviously for a liter (1000ml) of solution, you would double everything.
After the wash cycle, a thorough rinse cycle using only distilled water is also necessary.
If anyone decides to buy the ingredients and make this, you will quickly find that Hepastat256 comes in bottle sizes of like 64oz and up...you may get lucky and find a 32oz bottle. Using such a small amount of the concentrate per batch, these big bottles of Hepastat would last 5 lifetimes for just record cleaning. Luckily, Hepastat256 has another household use (its real use) as a disinfectant cleaner. It is used in hospitals and restaurants for this purpose. In a 16oz spray bottle, 2ml of Hepastat mixed with water is a good disinfectant cleaner (4ml for a 32oz bottle). It kills a host of bacteria and germs, and is easier/safer than bleach cleaners. We spray it on our kitchen countertops."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
You lost me at "pipette".
Haha, that's 'cause your vinyl care regimen is a couple of sharp blows and quick brush with a hairy backhand!I disabled signatures.
Ha..not surprising, Drew. I know you are a very 'low maintenance' audiophile
Pretty much. I have been known to use the tshirt I'm wearing to try to wipe dust off of a record before playing it.
Too funny. I *might* use my t-shirt to wipe off a dust-cover, but that's it. Cleanliness is next to Godliness...in Boy Scouts and in vinyl."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
In related news, another record from Amazon arrives in their custom flimsy cardboard mailer. This is printed on it:
"Certified", eh? Seems like it would be a lot more accurate if it just said "Certified Frustration" and nothing else.
Because when I open it up and see a creased jacket, that's FRUSTRATING.
Where does one buy 99% isopropyl alcohol at?
My local grocery store carries it:
Or Amazon."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I ordered 99% from Amazon. Swan makes it in their regular pharmacy-sized bottles, or you can get lab grade.I disabled signatures.
Best I can get is 91% anywhere.
Guess I'll needle my local pharmacies. I've never seen it available over the counter here. My sister company orders a gallon jug for the cleaning of the printing presses. I'm however not able to get ahold of any. -
99% was a little scarce for a while, I think, because people were buying it to make hand sanitizer.I disabled signatures.
Guys, PM me if you want a small amount (50ml or so) of Hepastat256 quat. Shipping/packaging cost is all I require."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Thanks Jody that is very generous of you.
91% does work for my needs it just takes a longer soak than I think it would for 99%.
Happy to help, Ivan. How much is 8% of contamination worth to your vinyl collection?
No vinyl here I'm 100% polycarbonate -
I'm confused - so what do you use the 91% for, and what are you soaking?I disabled signatures.
Removing hot melt glue, flux and other residues Scott
My kid also uses it on his vape pens to clean coils -
