repost in right sub: I was playing my PS4 on my MagniFi MAX SR and then it just went down..
luism
A little amber light started blinking continuously I tried resetting with the remote no luck, I tried also unplugging and replugin but this time nothing occurred it was just dead, I did notice that the right side of the bar was extremely hot.. so right now I unplugged and let it cool down to see what happens..
Any ideas? What does that flickering/ blinking light mean?
Update: I called Crutchfield (where I bought it from) we tried plugin power source from wall and resetting it, still no response whatsoever from bar. Tried to see if connected it would be in the wifi, but no luck (using google home app)
Crutchfield tech recommended I call Polk.
Will Polk fix it? I want to try that option since the system was 600 bucks..
Thanks..
Thanks..
You'll have to call Polk.Political Correctness'.........defined
