Decent haul
Vette C6.r
Picked up 12 MIT interconnects for $20 at a nowhereville antigue store today.
Wow.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
You must've done a double-take when you saw them.
Which model is that? Is it stamped onto the boxes?
Good thing you had your truck. There's no way you coulda fit those into a car. Might wanna check for leaf sag now, too.I disabled signatures. -
Terminator 2s. Not the best but decent to have around.
Actually grabbed them all and said $20. That was a pic when I finally counted them. Just separated them on the truck. -
Deal of the year maybe.
Nope, that would be the 4K Oled TV's that Best Buy and Target were giving away across the country a couple weeks ago, if you didn't mind a little smoke inhalation.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Early cables are like computers. You may think you've found a gold mine but what you've actually found is a bunch of old junk no one wants unless you're a collector of old junk.Gustard X26 Pro DAC
Would this qualify as raining on someone’s parade?
Things work out best for those who make the best of the way things work out.-John Wooden -
raining?? that's a downright down pour...…
very nice sag for the $$$$$$ -
I'd paid 21.00 for em
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Should have put them on the ground. It looks cleaner.
It's a truck. Looks like a Toyota bedRandy-Maine
by David WMG
Shortbed tooRandy-Maine
by David WMG
Hard to beat for a 20 spot- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Very nice haul; FWIW I've paid much more than that for just one pair.
