19192949697132
  • Gardenstater
    Gardenstater Posts: 2,184
    Looks like they also have copper tubing if you want to water cool them :D
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    audioluvr Posts: 3,873
    That's where the flames shoot out
    Cambridge Audio 851N Streamer/DAC
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
    mhardy6647 Posts: 28,687
    plus -- I mean -- how often do you see a really sexy looking resistor?
    This is the best I could do, for example -- admittedly, this would be pretty cool in an XO, but I only have one, so it'd have to be mono until & unless I can find a pair.
    treitz3 Posts: 14,816
    Oh, there are some out there that are good lookin' ohm walls. The ones pictured in the bottom photo are ready to be installed into my crossover units. Looking forward to listening to the end results.
    ~ I have found excellence ~
    ~ The best way to enjoy digital music reproduction is to never listen to good analogue reproduction ~
    pitdogg2 Posts: 19,956
    what do you do with the 3rd wire on the path Tom?
    Those are to be connected directly to ground. Here is a snippet from the website...
    "Resistors are made in thick film technology. The resistive layer is applied to the ceramic molded body. Then it's drying with high temperature and encapsulated with silicon cement. After applying 0.8mm tinned copper wire, the resistor is almost ready to play, but for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
    I gave serious thought to ordering some for the 2.3tls but that 3 wire threw me.
    Sounds to me like it's just a shielding energy dump to help lower the noise floor or unwanted electrical interference. I will be wiring it to ground in both crossovers.
  • jdjohn
    jdjohn Posts: 2,242
    Does that make them directional...dare I say, diodes?
    No. The copper shield and grounding harness are completely separate from the resistor.
  • NotaSuv
    NotaSuv Posts: 3,404
    Changed out the Parasound Halo Integrated Amplifier for a Plinius Hautonga Integrated Amplifier, looking at the Plinius for awhile now....have owned a few of their amps in the past great sounding and never a problem....
    Clipdat Posts: 10,294
    edited June 2020
    That's a neat and tidy internal layout on the M2si. I like how the transformer is located well away from the output transistors and the speaker wire leads. Should help keep the noise floor low.
  • halo
    halo Posts: 5,612
    Thanks Drew! It’s putting a smile on my face. Very simple and straightforward design.
    treitz3 wrote: »
    those look
    * good
    * purposeful
    * expensive
  • halo
    halo Posts: 5,612
    edited June 2020
    After acquiring a nice Halo A21, and having it in the Stereo for some time, I couldn't help but wonder what the JC5 would bring to the table.
    After keeping a close eye on a few different used ones, I was able to come up with a near perfect "Dealer Demo" JC5 that also came with the Full Factory Warranty.
    This has been a Destination Piece/Purchase for me, I had to pull out about all the stops to make this happen. But, I'm elated that I did. The JC5 is nothing short of amazing.
    Congrats Mike!!
  • Milito
    Milito Posts: 1,445
    Mike nice setup, congrats!
    Yamaha RX-A2070, Music Hall A70.2 integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Polk L600's, L400, Audioquest Interconnects and Digital Cables, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios.
  • joecoulson
    joecoulson Posts: 4,944
    I want one too. Congrats man!!!
    The JC5 is definitely a beast and something I'd love to have it as well.
    Way to go Mike congrats!
    Looking forward to hearing more about how it sounds vs the A21 as you get more time on it. Nice pickup for sure, Mike!
  • indyhawg
    indyhawg Posts: 1,577
    edited June 2020
    Congrats Mike. I would also like to hear a comparison to the A21.
  • butterbean
    butterbean Posts: 352
    Got estimates for crossover upgrades. That’s gonna have to wait a bit lol 😂 but I put dynamat on the baskets of my drivers and passive radiator and some acoustic foam behind my drivers as directed by westmassguy. Much more guitar layering. Really brings the mids out! Drums especially kick is stronger! My wife is thrilled!!!!
  • CH46E
    CH46E Posts: 3,383
    butterbean wrote: »
    What speakers?
