Just purchased the s60s -- question about what receiver to get?
New here--If I only plan on using the s60s for music in the 2.0 setup, not for surround or home theater, do I still need to drop big $$$$ for the pioneer elite like I read in an earlier discussion, or can I get something in a lower price range and still do the s60s justice? I guess my question is, what is the most affordable receiver I can purchase that is appropriate for the S60s. Thanks!
    F1nut Posts: 49,794
    For 2 channel music you definitely do not want an AVR, you want either an integrated amp or separates.
  • rooftop59
    rooftop59 Posts: 7,973
    edited June 2020
    alextwolfe wrote: »
    Yes that would be much better than an avr. I really think you should step up to the 801 to power those towers...looks like the 701 and 801 are basically the same except the 801 adds a usb DAC, so if that’s not important you could save $100 and get the 701...
    Game Room 5.1.4:
    Bedroom 2.1
  • Kex
    Kex Posts: 4,928
    If you don’t mind the “no frills” aesthetics, this NAD C316BEE V2 is a great deal from a very reputable dealer (Safe & Sound).
    NAD Electronics C 316BEE V2 Stereo Integrated - Refurbished - $315 shipped.
    Includes a toroidal power supply, and is 4Ω stable (without resorting to the use of a “safety” switch, like some systems).
    I have owned both NAD and Yamaha, but neither of these exact models. I would expect NAD to have much more authority than Yamaha, with more dynamic sound, especially for two channel.
    Alea jacta est!
  • rooftop59
    Kex wrote: »
    Dude that weighs 12 pounds. I would be highly a skeptical that it can push anything other than a very small or very efficient speaker well...
    Game Room 5.1.4:
    Bedroom 2.1
  • Kex
    Kex Posts: 4,928
    edited June 2020
    I saw that too, @rooftop59, but I’ve never met a NAD that couldn’t drive with more authority than the specifications might suggest.
    The Yamaha doesn’t have a toroidal power supply, and uses a limiting switch to protect itself from damage with speakers rated 6Ω or lower. That to me implies that it doesn’t really have the same grunt, which is also what my experience with the brands would lead me to expect.
    Neither are bad options, though. Marantz and Cambridge Audio would also be worthy contenders. It’ll be tough to beat the performance for just over $300, though.
    P.S. Buying from Safe & Sound is also a much better proposition than A4L, if there’s ever a need for customer service, after sales advice, or a return request.
    Alea jacta est!
    Clipdat Posts: 12,599
    rooftop59 wrote: »
    Well, you'd be wrong.
  • halo
    halo Posts: 5,616
    Clipdat wrote: »
    rooftop59 wrote: »
    I agree. The "power envelope" technology developed by NAD works very well and the C 316BEE that I have has had no issues driving the Polk L200 speakers or the ELAC DBR62 speakers. FWIW, towers are actually easier to drive than their bookshelf counterparts. Cambridge Audio CXA60/CXA80 would work very well. Musical Fidelity M2si. Denon PMA-600NE/PMA800NE. I haven't personally heard a Marantz or Yamaha integrated amp so I can not comment on them.
  • TopperDude
    TopperDude Posts: 166
    Look into the Marantz PM7000N streaming integrated amplifier. Have tried it personally with the S60 with great results and the streaming features are super convenient if thats your thing.
