2nd Centre Channel
Any of you folks use 2 Centre Channel Speakers in a 6.1 HT setup.? I have one centre plus front & rears and wondered what a 2nd Centre would be like. Thanks for the info.
Michael
NORTH of 60°
NORTH of 60°
Post edited by janmike on
My roomate is a proponent of using a bookshelf pair as a center separating that sound field. His old yamaha reciever has two center out ports. But I'm not sure what the proper way to do it is w/o splitting your impedance
Yup... One above the old picture tube and one below. Focuses the sound better "in" the picture than just one above.
Do remember to recalibrate, if you add a second center...More later,
Tour...
Vox Copuli
Hi Michael,
I assume that you're referring to two center channel speakers in the front as opposed to two surround back speakers?
Like Tour2ma I like to stack my dual centers over and under my projection screen. I have a 7.1 configuration where my Lexicon surround processor produces stereo surround back channels. Some folks feel that having two speakers producing the same mono signal introduces comb filtering distortion, but I haven't been able to hear any ill effects.
Instead of running them in series or in parallel from the same amplifier, I preferred to give them each their own separate amplifier.
You can view my setup by clicking on the link in my signature.
Larry -
Thanks for info. Larry, you are correct. I am looking at the possibility of 2 centre channels; 1 above & 1 below. It was just a thought. I recently purchased a new CSi5 and now there is a CSi40 (the perfect match for my fronts & surrounds) for sale and it is for sale in Canada. If I purchased the CSi40, I was going to review both speakers with MY NEW SIGNAL CABLES that are on the way from Frank. From there, I could determine which one I liked the best and sell the other. Then I though, what would it be like with 2 centre channel speakers (not identical, but close according to POLK). Just a thought as this darn audio bug has me by the short & curlies. When I married my wife 9 years ago she made me give up skydiving, so perhaps I have found another release outlet. Too many conversations with Jesse will do it also.Michael
NORTH of 60° -
You mean even one conversation with Jesse...
Agree with Larry's "amplification" of my rather terse reply... If you have a spare channel of amplification, use it. If not, wiring in parallel will yield a 4-ohm load, but with the system recalibrated for the twin centers, I wouldn't think it would be all that bad for a decent amp/ AVR.More later,
Tour...
Vox Copuli
Hi Michael,
Well, if I had to deal with the weather that you have, I'd be throwing myself out of airplanes too!!
But... if you keep listening to the guys on this forum you might find out that this hobby may prove to be more hazardous to your health, at least as far as your wife's concerned.
Larry -
Actually, the weather today is quite nice. I was outside for over 3 hours today and it was actually very pleasant. It is amazing how one becomes acclimatized to an environment. This sure beats
-58 (with the wind) that we had last month.
Yellowknife, Northwest Territories (TextWeather: YEL)
January 30, 2005
-28°C
Partly cloudy WIND calm
GUSTS
RELATIVE HUMIDITY 62%
DEWPOINT -33°C
PRESSURE 102.14 kPa
VISIBILITY 24 km
CEILING 21000 ft
Updated : Sunday January 30 2005, 16:00 MST - Yellowknife Airport
I have a Yamaha RX-V1500 and looking to add a separate amp, so I do not think I should have a problem.Michael
NORTH of 60° -
I also have a yamaha reciever that has 2 outputs for center channels. I only used one until I got a 65" widescreen and the cs300 did not seem to fit. Ran across a deal on a csi 40 and it was alot better and then found another csi 40 on closeout and bought it. Seem to fill in alot better.
Rob Sternmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
January 30, 2005
-28°C
GUSTS
DEWPOINT -33°C
PRESSURE 102.14 kPa
VISIBILITY 24 km
CEILING 21000 ft
Well, not to rub it in.
Today the high was 72 degrees F.
Here's our current conditions (the low):
Sarasota-Bradenton Intl Airport
Last Update on Jan 30, 6:53 pm EST
Fog/Mist
59°F
(15°C) Humidity: 93 %
Wind Speed: NW 6 MPH
Barometer: 30.02" (1016.6 mb)
Dewpoint: 57°F (14°C)
Visibility: 2.00 mi.
Larry -
Thanks Larry, you just warmed me up. We have to resort to indoor beach days during the winter months in YK.Michael
NORTH of 60° -
found a good thread, look down to jmierzur's comment: http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=24242&highlight=CSi40
