Signature S20E Black: How to remove RED label/sticker?
MladenK
MladenK Posts: 2
Hi,
I have maybe small aesthetic problem with Signature S20E speakers which does meter to me.
Issue:
I would like to remove RED information sticker which is glued on each speaker but there is no easy way to remove it without tearing it off. I would expect that it should be easily removed as most info sticker on audio devices.
Now, I have no problem with tearing-off the stitcher but I would like to know how can I remove leftover of the sticker from the speaker. I could use turpentine, white spirit, alcohol or any other sticker removal substance but I am afraid that this will damage the surface of the speaker.
I wonder how did you remove the mentioned sticker since I assume all POLK speakers have such a sticker glued on the top surface?
I did contact reseller(s) of POLK products here in Netherlands and even in USA but unfortunately they did not provide satisfactory solution to my "problem".
For more explanation please see attached pictures.
Have fun
Regards,
Mladen
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    That looks like a product description label that is placed on the speaker whenever it is placed on display in the store. Normally it doesn't come with the speakers, I'm sure the adhesive is very tough.
  • rooftop59
    rooftop59 Posts: 8,120
    Goo gone should do the trick
    Game Room 5.1.4:
    Bedroom 2.1
  • MladenK
    MladenK Posts: 2
    Guys :) , thank you very much for your comments and advices.
    Eventually I removed the stickers with sticker remover and carefully crabbed off remains of the sticker.
    Have fun
    B)
