How limited am I? Look at this mess!
  • afterburnt
    afterburnt Posts: 7,892
    Wait you can see a couple behind the rack ib the first pic
  • Gardenstater
    Gardenstater Posts: 4,785
    edited June 2020
    I see them now on the far left. If they are forward facing, a Bass Brace would be a good idea, for the one on the top especially. I tried it with my Martin Logan and it worked fantastically. Of course mine is spiked to a pair of concrete blocks with 2 bicycle tubes in between them and viscoelastomeric damping material between the bottom block and the floor, but it really is the best of both worlds......vibration isolation from the floor and rigidity from the brace. Matthew Polk was wise.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • afterburnt
    mhardy6647 Posts: 35,140
    afterburnt wrote: »
    @Gardenstater what's a bass brace?
    I believe it is a medical appliance for fish with vertebral problems.
  • Gardenstater
    The bass brace is a Matthew Polk invention that I believe he first introduced with the SDA SRS 2.3 and 1.2's. From the Nov 1988 Stereo Review, where they reviewed the 2.3:
    Another innovation of the SDASRS 2.3 is the Bass Brace. A powerful low -bass signal would cause all seven bass diaphragms to operate in phase, and that might rock or vi- brate the entire system back and forth slightly. Designer Matthew Polk was concerned that these shifts would cause frequency modulation of treble tones that might degrade
    the clarity and image focus. To deal with the same problem, smaller speakers are often mounted on spiked feet to anchor them to the floor. This would probably be an
    impractical solution with the large, heavy SDA-SRS 2.3's, but Polk came up with an ingeniously simple alternative. Several lengths of threaded steel rods are supplied that
    can be screwed into a fitting on the rear panel of the speaker, adjusted to fit between the speaker and the wall behind it, and screwed into a complementary wall fitting, which can be screwed in place or fastened to the wall with double -sided adhesive tape. With the Bass Brace installed, the cabinet is firmly re- strained against rocking or vibration. According to Polk, it makes a definite improvement in the imaging stability of the system. (The Bass Brace is also now standard with the SDA-SRS 1.2.)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • daddyjt
    daddyjt Posts: 3,116
    While ingenious and intriguing, it does take the already tenuous WAF of the SRS and drive it right off the cliff... :wink:
    ― Aleksandr Solzhenitsyn
  • Gardenstater
    That's about the only problem I don't have right now (WAF) :p
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
