Polk Monitor 75T question
Hello all, new to the forum and hoping for some guidance. I have two Polk Monitor 75T towers that I bought back in 2013, but hadn't used for about two years. Yesterday I connected them to my receiver and only the tweeter was working on both. I took out a speaker out of each tower and directly connected them to the receiver and they worked fine. Checked all connections, placed them back but only the tweeter works when I connect to the tower. I am thinking it's probably something with the crossovers. Any other tests you would recommend? Is it possible te replace the entire crossover board and are they sold somewhere? I don't know how to solder but willing to learn.
    F1nut Posts: 51,756
    Are your jumper plates installed?
  • aps2020
    aps2020 Posts: 5
    Hi F1, I bought these new and no one has messed with them, so yes everything is intact and in place.
    F1nut Posts: 51,756
    Famous last words....lol
    Post a picture of the binding post plate area please.
  • aps2020
    aps2020 Posts: 5
    Lol...here you go.
    F1nut Posts: 51,756
    edited May 2020
    Ok, jumpers are there. Did you remove the binding post nuts from the top posts for the picture?
    F1nut Posts: 51,756
    edited May 2020
    Ok then, I take it you are connecting your speaker cables to the top posts. Try connecting them to the bottom posts and make sure all the binding post nuts are screwed down tight.
    Are you using banana plugs, spades or raw cable ends?
    F1nut Posts: 51,756
    Where did he go?
  • aps2020
    aps2020 Posts: 5
    Sorry F1, got delayed at work. So on the bottom post I get no sound from the tweeter, sound from speakers 1 and 2, but no sound from 3 and 4. With 4 being the ones I tested before and worked when connected to the receiver. Same behavior on both towers.
    F1nut Posts: 51,756
    edited May 2020
    Ok, the jumper plates are not making a connection. If you are using unterminated speaker cable it's not allowing the binding post nuts to clamp down tight enough. Get some banana plugs or strip off some insulation a bit further in from the end, then run the speaker cable through both binding posts.
  • james310
    james310 Posts: 2
    I wish this forum was around when I was younger a lot younger lol! I could have saved a lot of cash !!!
    pitdogg2 Posts: 27,040
    james310 wrote: »
    Or you could have spent twice as much!
