Well It Sounds Like One of My Tweeters on one of my 705's is Bad
Milito
Milito Posts: 2,003
I just did a sine sweep test tone to check my speakers as they haven't been sounding as good as they use to. I thought it was maybe my ears as I wear hearing aids. I had forgotten I had a sound quality reference CD so I decided to test them.
My left tower tweeter is making a slight popping sound. I called Polk and had to leave a return phone call number for them to call me. I hope they do and this doesn't become a long drawn out issue.
  • PSOVLSK
    PSOVLSK Posts: 5,398
    Hope they get you taken care of quickly.
  • Milito
    Milito Posts: 2,003
    Thanks, me too.
  • Upstatemax
    Upstatemax Posts: 2,782
    Not sure if you have done it yet, but did you try with different sources and check all connections?
    Several years ago I had a Preamp/DAC that caused a similar issue.
  • Milito
    Milito Posts: 2,003
    Yes I have, thanks.
  • Milito
    Milito Posts: 2,003
    edited May 2020
    Talked to Polk and they're sending me some tweeters. :)
    pitdogg2 Posts: 27,239
    check the resistors as well might have toasted one.
  • Milito
    Milito Posts: 2,003
    OK, thanks. They said it might be 2 weeks or so before I get the tweeters.
