Preamp with Home Theater Bypass?
swegyptian
swegyptian Posts: 316
edited May 2020 in 2 Channel Audio
Hi all,
I’m considering a new preamp, as my Parasound P5 is acting up a bit. I should probably just have it serviced, but you know how our brains work....
So basically just use a Sonos Connect, so I’d like a DAC in the pre, and I really like having home theater bypass, but that’s it. If I could get really picky, I’d ask for XLR connections, too. But overall I don’t need other connections. What would you guys consider?
Thanks,
Alex
  • DaveHo
    DaveHo Posts: 3,582
    PS Audio Stellar Gain Cell DAC/Pre. Hands down better than the P5 which it replaced in my rig.
  • swegyptian
    It does look great, but am I missing the home theater bypass feature?
  • jdjohn
    jdjohn Posts: 3,373
    I know @joecoulson likes his P6 better than the Stellar GC Pre/DAC. I believe he said the bass management is what sold him in the end.
  • Mikey081057
    Mikey081057 Posts: 7,127
    DaveHo wrote: »
    +1 on the SQ of the PSA SGCD... However the Stellar does not have sub woofer mgmt like the Parasound...If you need that.... There are other (better) ways to accomplish that too..
    Garage | Polk Monitor 5B's
  • swegyptian
    I don’t use the sub out on my P5, but the home theater bypass is a must. I don’t want to run totally separate systems.
  • jdjohn
    jdjohn Posts: 3,373
    Then the PSA SGC Pre/DAC might be the ticket. It has one pair of XLR inputs and a pair of XLR outs as well.
    You might say I'm a fan:
  • DaveHo
    DaveHo Posts: 3,582
    It has ht bypass. You can choose one input to be set to unity gain. Yes, this means it needs to be on when using it for ht.
  • jdjohn
    jdjohn Posts: 3,373
    There's even a button on the remote for toggling 'HT' on-and-off.
  • swegyptian
    Ah, thanks everyone. I didn’t see the dedicated input but it sounds more like there is a toggle that can bypass the volume control on the unit and then HT Bypass is done on whichever in put you like. It does seem like the right unit. Now, to hunt out a used one!
  • DaveHo
    DaveHo Posts: 3,582
    PS Audio has a trade in program. IMHO, they give ridiculously high values for used gear. Might still do better on the used market, but it's worth looking into. What's going wonky with your P5? Parasound has a good track record of fixing out of warranty gear for free.
  • swegyptian
    Good info. The volume knob was a little noisy, but now half the time I have reduced output and distortion in one channel. Sometimes fiddling with the knob will help. It’s pretty minor but obviously a deal breaker. I know it would be cheap to fix, but right now nothing being open makes buying another unit super tempting.
  • jdjohn
    jdjohn Posts: 3,373
    Is that volume pot serviceable...cleanable with DeOxit?
  • swegyptian
    I have deoxit, I should probably open it up and see. Are some pots not serviceable? Is there a way to inspect that?
  • jdjohn
    jdjohn Posts: 3,373
    Yeah, a visual would help, but someone here probably knows off the top of their head for that unit.
  • HzTweaker
    HzTweaker Posts: 1,009
    The PSA SGCD is the upgraded route I'm going this fall! I can't wait to get my hands on one. Looking forward to your thoughts on it if you purchase one @swegyptian
  • BlueFox
    BlueFox Posts: 15,250
    swegyptian wrote: »
    Take the knob off and spray the shaft. Turn it up/down. Repeat. Good luck.
  • jdjohn
    jdjohn Posts: 3,373
    A more thorough servicing requires that the preamp's cover be removed, and then try to access ports on the volume potentiometer from the rear. Ok pervs, don't try to make this sexual.
    Come on, Bud ... "up/down"(?) ... are we talking about old slider volume controls here? ;)
  • BlueFox
    I meant volume up/down. That is left/right with the volume knob. Of course, have it turned off while doing this. :)
  • gmcman
    gmcman Posts: 1,857
    This is a good thread as I'm in the same boat. I would like to compare DAC's as well as a preamp/DAC to my McCormack RLD-1 SA8005 combo. I've been looking at the PSA SGCD also.
    jdjohn wrote: »
    Interesting....was this for overall bass or specifically for subwoofer options?
  • Mikey081057
    edited May 2020
    The Anthem is a bit pricier but is a very nice unit... and has bass management for 2 subs. Also has room correction.
    https://www.anthemav.com/products-current/series=str-series/type=pre-amp/model=str-pre-amplifier/page=specs
  • DaveHo
    DaveHo Posts: 3,582
    Noisey volume pot is a common issue with the P5. That's one issue I know I've read about them fixing out of warranty. Shoot Parasound an email and see what they say. Most likely Richard Schram himself will answer it.
  • motorhead43026
    motorhead43026 Posts: 4,017
    ^^ this, I had 2 pots put in my P5 before it was fixed.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • swegyptian
    Thanks everyone, sounds like I’ll try Parasound next week and go from there!
  • DaveHo
    DaveHo Posts: 3,582
    Oh, we're still here to help spend your money. But, a fully functional P5 will be easier to move to help you do that!
  • rburgess714
    rburgess714 Posts: 618
    Using the P5 and had the same volume pot issue some time ago. Parasound support was fantastic.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
