Identify a Monitor 10?
waylyn5945
I have Monitor 10s. There is absolutely no identification tags on them. The only definitive feature that I've seen is that the tweeter is brushed aluminum with "Polk Audio" written on the bottom. (I don't have a digital camera so I can't attach an image). I'd like to identify so I can get decent specs - particularly db efficiency.
Wayno
Post edited by waylyn5945 on
It's either an original Mon10, or the Monitor 10A. They were the only ones who used the SL1000 tweeter, according to Polks website, and that was the only tweeter (I believe) that had the "Polk Audio" logo in the SL 1,2,3k seriesLudicrous gibs!
This thread may answer all of your questions:
http://clubpolk.polkaudio.com/forum/showthread.php?threadid=14441&highlight=scans -
Silver face = SL1000 which means 10A's or B's. Which depends on whether the MW's are 6500's or 6501's.
Original 10's had the Peerless tweeters.More later,
Tour...
Vox Copuli
what would happen if you installed a Peerless tweeter in a monitor 10 say. that didn't originally have a peerless tweeter? would it sound really bad or would it be ok?PolkFest 2012, who's going>?
Doro recently indicated that this wouldn't necessarily be audible, any problems caused by crossover issues, I mean. I think that a side-by-side would be helpful in reaching that conclusion. Perhaps doro has done this, I don't know.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
The original Monitor 10 and 10A's that I knew all had Peerless tweeters (with the hole in the middle of the dome).
One other identifier that I noticed. The name tag "Polk Audio" is not printed on the grill like others that I've seen. It is below the grill, mounted on the cabinet.Wayno
