Golden Ear BRX
joecoulson
in Speakers
I was wondering if any of you fine scholars and maybe some of you ruffians have heard a set of these and if so, thoughts?
I'd be curious to know those are near field monitors correct? There is a pair of Golden Ear Aon 3 in my neck of the woods I was curious about priced pretty good. I can tell you the big pair of Golden Ears I heard last year at Apoxona were terrible I couldn't get out of the room fast enough.Home Theater
THIS.
Definitive and golden ear, imo are movies and gaming speakers first- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I thought it was just me. Every pair I've ever heard were bright and I couldn't get them turned off fast enough. I don't even know the model numbers, but I've heard two pair so far in different settings.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
I’ve also heard Golden Ear on a number of occasions at different locations and haven’t been impressed. The set-up at Axpona was brutal._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
