Looking forward to L800 but have concerns, what are your thoughts?
    nooshinjohn Posts: 25,100
    edited April 2020
    mhardy6647 Posts: 33,046
    edited April 2020
    There is no replacement for displacement....
    You'll never get any argument from me on that front. :)
    Paul Klipsch once said something to the effect that miniature speakers would be fine -- if they could figure out a way to miniaturize the sound wave from a 32 foot organ pipe*.
    Or words to that effect. B)
    ______________
    * For those of you playing along at home, that's 16 Hz. :#
  • jdjohn
    jdjohn Posts: 3,004
    Sorry if this has already been answered, but was there ever a consensus on whether the L800 require a common-ground amp in order to work properly?
    F1nut Posts: 49,802
    They do not need a common ground amp. However, differential balanced amps cannot be used.
  • FTGV
    FTGV Posts: 3,649
    edited April 2020
    According to Stereophile's measurements, the Cambridge was near text book in that it doubled it's output into 4ohms and again an impressive 430watts into 2 ohms. Current limiting doesn't appear to be it's biggest shortcoming. https://www.stereophile.com/content/cambridge-audio-edge-integrated-amplifier
    Clipdat Posts: 12,607
    The Cambridge Edge A was never the issue.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    CxzRW9s.gif?noredirect
  • FTGV
    FTGV Posts: 3,649
    Lol ,it's a tough old horse.
  • ptrooper
    ptrooper Posts: 501
    It took around 300hrs but the L800's are now really sounding effortless!
  • ptrooper
    ptrooper Posts: 501
    edited April 2020
    It’s not M10 but close 😎mmm, either a threaded tube bush to 1/4. 20. Or a mission for a friend 😛. 5hdnso6g0i76.jpeg
    Polk typically used 1/4-20 threads, but I think some of the newer stuff is 6mm.
    F1nut Posts: 49,802
    I'm not following you.
    pitdogg2 Posts: 24,579
    He bought/guessed the wrong thread.
  • JayCee
    JayCee Posts: 1,479
    ptrooper wrote: »
    GAIA 2’s. Does any one know the thread size needed on the L800.looks like M10 ,Isoacoustic should supply these.
    JayCee wrote: »
    You might shoot Musicdirect an email as they sell both. They're pretty good at answering Q's.
    Either 1/4-20 or 6mm. Best send an email to Polk to be sure.
    pull yours off and use a thread gauge to be sure. I'm thinking they would be something like 1/4" x 20 tpi
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • ptrooper
    ptrooper Posts: 501
    Sorry F1. Isoacoustics only supply 4 different sizes with their Gaia's so i am considering buying some 3/8 (Size of speaker thread) and drilling and rethreading the centre out to take one of the other smaller sizes.
  • vmaxer
    vmaxer Posts: 5,116
    ptrooper wrote: »
    Something like this?
    https://www.ezlok.com/e-z-lok-solid-wall-threaded-inserts-for-metal
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ptrooper
    ptrooper Posts: 501
    I tried ordering the correct thread with my first SDA SRS set but had to actually have m10 to m6 made !..reps here just give you the sets they have in supply which carry m10 m8 m6 and 1/4 20 .
    I have just banged out an email directly to Isoacoustics for the 3/8 being L800's to isoacoust GAIA 1,s being M 10.
    Lets seee if they can come up with the goods. : )
  • marvda1
    marvda1 Posts: 4,873
    Contact isoacoustic, they have other thread sizes not supplied with the gaias.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • ptrooper
    ptrooper Posts: 501
    Sadly,Isoacoustic only responded to which ones to buy and ignored the three emails regarding purchasing the necessary thread for the L800 being 3/8.
    Shame as i was actually going to buy a third set as they have a purchase now (until 30th april) here down under and get $200 back for each set purchased.
    F1nut Posts: 49,802
    What do you need, a 3/8" threaded rod and tap?
  • ptrooper
    ptrooper Posts: 501
    All sorted this side thanks F1, getting a local fellow to fabricate :)
  • mpitogo
    mpitogo Posts: 478
    @ptrooper How are the Gaia with the L800? Have you done anything else to them?
    My latest change was a swap of preamp from a SS C47 to a tube C70. I have them active bi-amp with a 370Hz 24db/oct xover and contemplating pulling out the bass passive crossover. I can actually tri-amp as I ordered the active crossover with the matching polk frequencies (switchable between 2-way and 3-way), and since there is an extra binding post, use them for the tweeter. Only problem is how to power the SDA.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • mpitogo
    mpitogo Posts: 478
    Thanks for the update. The GAIA's really look nice.
  • ptrooper
    ptrooper Posts: 501
    First reflection from rear wall sorted. Sound absorber to me. Art to the miss’s😀oh9qz94bwh5c.jpeg
    VR3 Posts: 28,042
    I like it!
  • Gardenstater
    Gardenstater Posts: 4,186
    ptrooper wrote: »
    @mpitogo ,Sorry for not replying sooner,i didn't notice any notification and i haven't been on for a couple of days,usually i'm logged in 24/7 B)
    Have fun triamping,Can't wait to hear about your gains!
    I have the GAIA 1's on my L800's and four isoacoustic oreo's under my bluray/pre ,these have been in place for around two weeks now. <snip>
    Very nice! What improvements did you notice with those GAIA 1's over spikes on your wood floor? Assuming you tried spikes, that is. If not, what improvements over factory equip?
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ptrooper
    ptrooper Posts: 501
    @gardenstater.I must admit the original polk spikes with rubber boots supplied do a great job!.I didn't try spikes alone!!!
    The Giai 1's stopped the back and forth motion in less time on the push/bump test but they definitely weren't rigid as if coupled to the floor.They tightened up the bottom end giving nice depth to the soundstage .
    The Oreo's under the JLTI oppo added subtle micro dynamics to the top end giving more air to the sound stage .My oppo 105d JLTI also has a few layers of dynomat installed! :p Inspired by a one of Dark Knight's post' from memory..
    I felt the L800s really relaxed from 700 hrs +,they have 800 clocked in now.
    When seated,our ears aren't at tweeter level !
    With movies,the L800's throw extremely dynamic micro details as if they were coming from other rooms.
    My "stock SDA SRS" didn't sound this good, but i didn't have the SRS from new so the original owner may have tripped them allot!! The tweeter protection would have shut them down at pressure lvls the 800's are doing comfortably.
    The L800's do need more power but they certainly are pillars of sound like their bigger brothers.
    I have recently rugged the wall and was amazed at how it also improved the bottom end .
    The tweeks continue .
    I would have done the crossovers for you for free Warren...
  • warren
    warren Posts: 756
    Thank you.
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
