Has anyone tried an Audyssey microphone in a Yamaha YPAO set up?
VXR8
VXR8 Posts: 291
Hello all,
As per above, has anyone tried the Audyssey microphone in a Yamaha receiver? I have the Audyssey microphone from my Denon AVR-X7200WA and recently also purchased the Yamaha RX-A3080. When running YPAO, it isn't quite as simplistic as Audyssey and though I haven't done the separate height measurement as yet, the sound appears a lot thinner on the Yamaha with the same speakers and set up with the Denon.
I'll be running the full YPAO set up again, including the second height check to see how that goes - am and hoping for an improvement in the "depth" of sound, but that failing was gong to try the Audyssey mic too, to see if that may assist in reaching the sound I am used to with the Denon.
Also, not sure if anyone knows how to overcome this, but when I play a multi channel SACD through the Denon, it knows it's 5.1 and outputs at that. With the Yamaha, it initially defaults to 7.1 - and even when you press "straight", it still plays at 7.1. However if I play a dedicated 2 channel SACD, it plays back in 2 channel only when straight is pressed.
What drew me to the Yamaha was the XLR input for my Cambridge Audio 851 CD player and the XLR pre out for the front channels for my Emo XPA2 amp. Failing the good sound that I like and am used to, the Yamaha probably will go.
Thanks in advance for all of your input, as always.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
  • rooftop59
    rooftop59 Posts: 8,120
    You can get a Yamaha mic for about $20 shipped on eBay. I would go that route...
    Game Room 5.1.4:
    Bedroom 2.1
  • VXR8
    VXR8 Posts: 291
    Thanks - I also do have the YPAO mic but was wondering if the Audyssey was a better option.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    No those mics are specific to their respective software.
  • rooftop59
    Agreed
    Game Room 5.1.4:
    Bedroom 2.1
