DSW Pro 550 ONKYO
Impred
I have had a Onkyo with a DSW 550 Pro sub, been working great for a few years, moved it around, now Sub LED goes on Green for +-2 sec then back to Red no response. No setting changed etc
Make sure the connections are correct and tight. If it still has the problem the plate amp has failed, a common problem with sub plate amps.Political Correctness'.........defined
