Right channel dropping out on B&K st125.2
Howdy y'all. It's been a loooong time since I've hung out here. I hope everyone's been doing well.
Looking for a bit of advice. A while back my right channel went out. I went through all the wires checking for something loose and accidentally bumped the power switch on the amp. As soon as I did the channel came back.
Now the same thing happens intermittently. Quickly pushing the power switch always brings it right back. It doesn't bother me that much but I'm a bit worried that there may be a failing component and by ignoring it I may cause serious damage.
What do you think?
Sounds good to me...
  • gyosa
    gyosa Posts: 770
    Try a new switch maybe ?
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    F1nut Posts: 52,049
    Yep, time for a new switch.
  • Rev. Hayes
    Rev. Hayes Posts: 475
    Sweet. New switch is no big deal. I thought it odd that only half the amp would cut due to a failing power switch but I suppose it actually is a single switch switching two independent sides. Makes sense.
  • Rev. Hayes
    P.S. If you ever get the chance to pick one of these amps up, don't hesitate. This is the ONLY issue I've had with it in 10 years. This despite my regularly abusing it. (I've even used it to simultaneously power sets of Infinity RSII, Maggies, Monitor 7, and Monitor 10 at stupid volumes for house parties.... don't tell anyone)
    F1nut Posts: 52,049
    A friend with one of those amps can't turn it off via the power switch, it does nothing when pushed.
  • Rev. Hayes
    Ha! I don't see the problem there. Why would you ever want the music to stop???
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,884
    Rev. Hayes,
    If there was ever a time to come back on the forum, now is the time.
    Harry
    Marietta GA
    Harry / Marietta GA
  • Rev. Hayes
    Harry speaks the truth. Only problem is it's giving me GAS. I thought I was finally cured...
  • gyosa
    gyosa Posts: 770
    I have replaced the power switch on my ex-442 at least 6 times since I bought it new ..
    They are notorious for failure.
    Last time I bought several as back ups .
    Bk
