WTB 6- RD0194 tweeters and 2- MW6510 drivers
Joshwest90
Let me know what you have. Just noticed the drivers in one of my SDA-2A went bad so I’m needed replacements.
Plenty of 6510's on ebay atm.
@pitdogg2 the SDA-2A can you use 6510 and the 6502? Or which is better
SDA 2a uses 2 mw6510. I've never run a mw6502 in mine.
As you can see they are WAY different...
MW 6502 1.97 5.16 N 1.47 E - 3N/M 3.52 Ohms 44 Hertz
MW 6510 1.39 6.32 N 3.41 E - 3N/M 6.57 Ohms 31 Hertz -
Anyway to rebuild these? Noticed this set crackles
The woofers, with power off, gently pushing in by hand evenly, being careful of your dust cap, not pushing too hard if you feel resistance, do they move in and out smoothly without any scratching?
my 3.1TLs
I will fix your shifted magnets for free.
A little scratch from on of them which is the one that sounds muffled and crackles with heavy bass songs
Ohm reading on it fluctuates between 6.0-6.7
