used receiver thoughts?
re510
i have a basic system and was thinking of changing my receiver currently i have a yammy HTR-5660. I use a carver av-405 amp.
the following receivers are ava. in my area
denon AVR-1803 $199
AVR-3801 $299
yamaha RX-V995 $295
RX-V590 $275
Pioneer VSX-D912 $150
onkyo TX-8511 $220
I know its nothing fancy but which one would you get (obviously ther all used)
denon AVR-1803 $199
AVR-3801 $299
yamaha RX-V995 $295
RX-V590 $275
onkyo TX-8511 $220
System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Post edited by re510 on
Have you considered the Denon AVR1905/785? It is a good receiver and can be had around $300 if you watch. Woodyjacobs has one for sale here on the forum if you are interested.Tschüss
Zach -
why replace the receiver with another receiver? Im not sure there will be a worthwhile improvement....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
The Onkyo TX-8511 is a 2 channel stereo only receiver with no pre-ins or outs.
Out of the group you listed at those prices, I would go for the Denon 3801. -
You can get a brand-new Onkyo TX-8511 from J&R for $240.00 shipped.
I have a Denon 3801 and love it...that's my reccomendation...
yeah after i read reviews i realized the onyko is a 2 channel
do you think the denon 3801 would be noticible or would it be better to sell the receiver and amp and buy a nice avr for around
800-1000?System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39 -
I have the rx-v995. Its a good receiver but I'm not sure it is your best choice with Polk speakers. I think a Denon might be a better match.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
re510,
2+2 brought up a good point. Why replace a receiver with a receiver? Have you looked into a 5 channel amp as an option? Maybe something like an Outlaw, Adcom or B&K? Youll get much better sound from something like that compared to another all in one receiver. Im in the process of trying to do this myself but the Im having a little trouble explaining to the wife why I want to use a $500 Yamaha receiver as a pre-amp and spend another $1500 or so on a separate 5 channel amp. Man they just dont get it.
O -
Yeah at this poiny i'm not sure which piece to upgrade the amp is pretty good. the receiver is ok too. I don't know which one to upgrade.System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
