I have been told that the 2m bronze I now have on this turntable needs about 50 hours to break in. I put about 8 on it today. I think it has about 15 now and seems to be opening up.
I have the same table, and also had a 2m Bronze on it..but I ended up going to a Denon DL-103 LOMC, and for me, it just opened up a whole new ear opening experience. It just took that table up a few notches..these Denon’s are special.
I have a Denon DL-103R that is potted in a Paradox Pulse Guard. A very good Cartridge for the price of admission.
When she wears down, I have plans on sending it to SoundSmith for their Ruby Cantilever upgrade. Owners have stated this takes the 103R to a whole different level.
SDA SRS 2.3TL's/SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Statement V2 cartridge and Origin Conqueror Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
Well John, I must say thanks for your recommendation! I love a great deal, and I think I got one with these babies! Only 3 hundie!
First impressions:
Exquisitely detailed highs! Airy, in fact. Mid's a bit less body, as compared to the SRS's (expected) and definitely in need of a sub! I knew the lower bass response would never match that of the SRS, just based on the specs, but still what was there had good attack and was never boomy. I'll play around with the placement a bit, but if you like bass, then this would be a great pairing with a good sub.
Very sensitive to toe-in. In fact, the manual recommends an equilateral triangle arrangement between the listening position and spacing between the speakers.
Overall, I am very happy! I like them very much. Sure, not the SRS big rig performance, but an excellent performer (and great value) overall.
Thank you sir!
Basement: Polk SDA SRS, Cary SLP-05 Pre with ultimate upgrade,Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Cambridge 851N streamer, Marantz SA-14 SACD, McIntosh MC300 Amp, Silnote Morpheus Ref2 Digital Cables, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Rotel RCD-1072 CD player, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
First impressions:
Thank you sir!
Do they recommend using a flashlight (from your listening position of course) to shine on the panels to make sure you are in the sweet spot?
Bought a few things to prepare for my (eventual) return home!
2 Channel - Dual Purpose system in the works
Polk LSIM707 I Polk LSIM 706C I Modwright SWL9.0 Anniversary Pre I Marantz AV7707 I B&K Ref 200.7 I Rega P6 w/ Ania MC I Rega Fono MC I Audience Ohno ICs/Audience Forte F3 Power Chord/Acoustic Zen Satori I Cambridge 851N
It's the Walmart version of the Ikea Kallax. I believe it's branded Better Homes & Garden. 8 square, there's two empty squares under the picture because new records are expensive but I'm getting there.
Bold choice leaving the bottom empty, but sounds like it's pretty solid if you have it that top heavy and don't have any swaying issues.
I laid them on their side and stacked them. I also left out two of the shelves when I built them. Gives more room to flip through the records. Very sturdy. I also like how I get to use the top. The stack of three has my R2R on top. And the 2 to the left serve as my working area for sleeves of records currently in play.
Legacy Focus SE, 2 REL Carbon Limited, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Denon DP-59l w/Ortofon 2m Bronze, Marantz SA-14s1, Oppo BDP-105, Technics RS-1500, Furman Elite 15PFi, Douglas Connection (Furutech) Alpha Interconnects, Douglas Connection (Furutech) Alpha Speaker Cables, Pangea Power Cables
(actually, the above-pictured catastrophe is, as most of y'all know, the result of "pilot error" -- to wit, assembling the shelving 90 degrees out of phase with respect to the correct configuration)
^^^^Sad as all it would've taken to stop that is one 45 degree brace in one of the squares
Or assembling the shelving correctly.
I reassembled one of mine after we moved and carelessly did it wrong -- someone noticed my gaffe when I posted the photo (me?! imagine that?!?) someplace on teh interwebs -- so I took it apart & put it together again the right way.
The horizontal shelves are full-width as designed. Put it together that way and all's well.
Assemble it with the full-width shelves vertically oriented and, sooner or later, hilarity ensues.
Of the Expedit now Kallax IKEA shelves would the 4X4 be more stable than the 5X5, if full of albums? I would have no issues buying more than one if needed. I currently have about 45 milk crates of albums. Thank you.
I am not sure how you can get more stable than the singles stacked like I have. A 4x4 is as easy as buying 4.
Thanks. I meant to say I would possibly buy two 4X4 units or two 5X5 units, to accommodate all I have. Just wondering if the smaller 4X4 unit was more stable if full of albums vs. the 5X5. I do like your stacked piece configuration as that is a possibility for a small listening room I have.
I put together a mini system for my work bench. I use Poweramp on my phone, that goes to a Logitech blue tooth receiver, hooked to a Mninwatt amp, driving a pair of vintage Optimus Pro LX4 speakers. Sounds amazing good for what it is.
Living room: Clearaudio Champion II turntable, EAR 834P phono pre, Auralic Altair DAC/server, PS Audio Quintessence power, DIY 6H30 Class A Linestage, ASL AQ1006 845 DT MKII mono block amplifers, DIY Altec/JBL speakers, DIY Baltic birch rack Sun room: DIY Nelson Pass B1 w/Korg NuTube pre, Technics SL-1700 turntable, DIY Anaview d-class mono block amplfiers, JBL C50 Olympus speakers with custom Smith horns, Mapleshade Samson rack Den: Onkyo TX-NR929 receiver, Oppo BDP-103 player, Behringer EP 4000 sub amp, Electrovoice DX-38 active, DIY EL-34 horn amp, Behringer NU6000 bass amp, Klipsch Jubilee speakers, Martin Logan Cinema center, JBL SAT2 surrounds, Danley DTS-10 sub Dining room: Pro-Ject RPM 1 turntable, Shanling CD-T1500 SACD, Sumo Athena pre, SST Ampzilla 2000 amps, Quad 2905 speakers
New and old technology, working together. Very cool.
Kind of like an 80 year old man marrying a 24 year old...
Thank you Harry, very kind of you. Being Retired, I'm afforded the time to set and enjoy anytime I feel the 'need', which is about every day
first impressions?
First impressions:
Thank you sir!
Vinyl: Fluance RT82 * Bottlehead Reduction + Integration Upgrade * KAB RF1
Video: Hisense 55H8F * Panasonic DMP-UB200 * Z-line Designs Elektra
Village Idiot of Club Polk
MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
Discogs
I have 5 of the Kallax. They are these:
Now I have a pair of 2x4’s Kallax for the records that work great.
Overall, really great solution.
Turntable - VPI Scout 1.1/Ortofon 2M Blue
Amplification - Parks Audio Budgie, Dared SL2000a, McCormack DNA 0.5 Deluxe
Speakers - GoldenEar Triton 2
__________________________________________________
7.1 Home Theater
Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ HT2050; Elite Screens 120"
Man Cave
Turntable - Pro-Ject 2.9 Wood/Grado Gold
Integrated Amplifier - Rogue Audio Cronus Magnum II
CD: Cambridge Audio
Speakers - LSiM 703; SDA 2A; Epos Epic 2
Soon
