Joule LA-100 has landed in Verb's house!
124»
  • verb
    verb Posts: 10,176
    edited March 2020
    indyhawg wrote: »
    Glad to see you have found an amp that matches up well with the Joule.
    Thanks brother! Seems like it pairs well with the lower impedance amps, like Butler, or the Odyssey mono's. Ya never know! :smile:
    Still some more playing to do. Check the tubes, maybe roll em, and try the tape loop output as @tonyb suggested.
  • maxward
    maxward Posts: 1,683
    How does it sound?
  • verb
    verb Posts: 10,176
    maxward wrote: »
    How does it sound?
    Well only after 30 minutes, as compared to the Pioneer Receiver/Pre-Amp that was in the secondary rig, not even close to a fair fight.
    The Pioneer most likely be destined for the garage rig. The Pioneer has remote, BT, option for pre-out, sub-out, which is what I need for that environment.
    But as expected, it really brought the 1C's to life! I want to spend more time with it of course, but a lot more revealing. So far, loving that combo! :smile:
    tonyb Posts: 33,069
    Glad it's working out for ya, rock on with your bad self.
