Sub 505 Red Light only
Hello, I recently moved my Sub from one room to across the hall into another room. I was very gentle with it, I even used a pillow so it would not bang against the new computer table I have while placing it in its new position. I tried every configuration, but the red light comes on. I tried to hook it up to another source, and start out the low volume and slowly raise it up, the green light and a bit of sound flashed on for a fraction of a second, but I was unable to repeat this. I have tried RCA, and the different hookups.
TLDR
SUB505 RED LIGHT STAYS ON AND WILL NOT FUNCTIoN OR CHANGE TO GREEN.
I have never pushed this sub, and use it in conjunction with a receiver. I have tried different outlets and surge, protectors, nothing works.
  • BlueFox
    BlueFox Posts: 15,250
    Appears to be broken. Good luck.
  • FestYboy
    FestYboy Posts: 3,861
    Time to open the amp up and repair the broken input signal joints. Likely a cold joint that finally gave way.
