Request for advice (re speaker surgery)
    nooshinjohn Posts: 25,977
    slow_polk7 wrote: »
    @drumminman
    That sounds logical enough, but one need only consider the case of a through-hole component on a PCB to realize that the solder is indeed responsible for current flow.
    In that application, yes.
    mhardy6647 Posts: 35,194
    I was astounded to learn (not that many years ago) that wire wrap is (as folks would put it today) the best practice for many connections. Apparently wire wrap done properly is gas-tight and mechanically extremely robust.
    https://www.jameco.com/Jameco/workshop/TechTip/wirewrap.html
    https://hackaday.com/2018/05/04/ask-hackaday-whatever-happened-to-wire-wrapping/
    Like many really timeless electronics innovations, it was (apparently) developed by the "telephone company" way back when.
  • StantonZ
    StantonZ Posts: 452
    Umm...no. I used wire-wrap (back in the day) for proto-typing, but I wouldn't want all the parasitic capacitance (and even inductance) that comes along with it...especially in high-frequency or ruggedized environments.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Kryten
    Kryten Posts: 79
    I also remember wire wrapping....Gawd we're getting oldER :# (wait, we are experienced, seasoned)
  • skrol
    skrol Posts: 3,456
    Then you would use a tool similar to the one below. I purchased one because my Pioneer pl-570 turntable used the wrap method (but soldered also because the pins were round) on power connections for the timing motor that I replaced.
    I still have one of those.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • drumminman
    drumminman Posts: 3,396
    Not really- the wire should go through the hole and be flat against the trace so the solder flows over top and holds it in place.
  • slow_polk7
    slow_polk7 Posts: 58
    edited March 2020
    drumminman
    I (dangerously) assume you are attempting to rebut my statement a ways back in this post.
    drumminman wrote: »
    IF that were true, you should be happy to eschew solder completely and, using an appropriately high-temp epoxy, simply glue your lead to the pad. In this way, you could completely eliminate the possibility of ever overheating a component, or of lifting a pad.
    I'm being facetious, of course, to make a point.
    In your explanation, solder is the equivalent of a piece of scotch tape, holding the lead against the pad. In a proper solder joint, the solder surrounds the lead, allows it to make electrical contact with the entirety of the pad (not just the tiny area the lead is resting on) and even travels a way up the lead towards the body of the component.
    Even more troublesome is the fact that to do what you're suggesting one would need to bend each component lead, so that after it passes through the hole, it makes a nearly right-angle bend such that it can lay on the pad and be soldered over.
