FS: B&K M200 Sonata Monoblocks
audioluvr
audioluvr Posts: 5,908
edited February 2020 in For Sale (FS) Classifieds
Selling my beloved mono's since the upgrade bug bit me. Cosmetically probably a 7 with some nicks and one having one bottom corner bent in a bit. Just been professionally serviced by Hi-Tech Audio and had all values checked anything out of spec was replaced with new, all solder joints reflowed, all new electrolytic caps with the main power caps upgraded from 15,500uF 75 v to 22,000uF 100v computer grade caps so they should be good to go for another 20 years or more. Stock rating is 200w @8 ohm 400w @4 ohm and stable down to 0.75 ohm. 150 amp reserve capacity
I'm throwing in a nice set of power cables and if anyone needs a Dreadnought to run these I can throw in a 750 vA one with speakons for a couple hundred more.
These do make a low "wump" sound and dim your house lights when first turned on.
These have the remaining warrantee.
Edit: these have the optional dual XLR balanced inputs
$1,600 OBO plus shipping
Post edited by audioluvr on
  • GlennDog
    GlennDog Posts: 3,152
    GLWTS ...
    might you be eyeballing the M180s?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    I was but ended up picking up this Belles 350A Reference.
  • verb
    verb Posts: 10,176
    Love the wump sound and dimming the lights! :smile:
    Here's the copy of the service record.
    Also not sure if this matters but these are consecutive serial numbers. I bought them from the original owner who used them in his recording studio but didn't do that any more. I've seen these for sale for about half this cost but they are old amps. They stopped making these in I believe 1993 so they are at least 27 years old and the older electrolytics get the more they degrade the sound. I have maybe 100 hours on the refresh so they probably need more breaking in. Also these really start to shine after being warmed up for a couple of hours.
    pitdogg2 Posts: 27,035
    audioluvr wrote: »
    I'm thinking the dreadnought is 800va
    Right! I stand corrected it is 800va.
  • gyosa
    gyosa Posts: 770
    Boy o boy ....
    Those are sweet !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • What?
    @verb hasn't bought them already??!!?!?!?!? :o:p
  • verb
    verb Posts: 10,176
    Deferring to you my brother! :smile:
  • gyosa
    gyosa Posts: 770
    Man , I WISH I needed these .....
    I have a soft spot for B&K’s .....
    Bk
    If you were closer I'd drop them off for you to audition. I'll probably rotate them back into my system in a couple weeks just to make sure I'm making the right decision. I still think the Belles just doesn't have the same low end torque that these have but everything's a give and take right? If I don't find a good home for them I'll probably have to move them into my barn system.
    These are no longer for sale. Thanks for looking!
  • gyosa
    gyosa Posts: 770
    I hope you decided to keep them ....
    Great amps which perform as new which you will never be able to replace !
    Bk
    My daughter and I did a day of A/ B'ing and decided we like these best.
    Clipdat Posts: 13,094
    I want these now simply because they are no longer available for sale.
    Are these still available?
    Nope. Stop teasing me...
    Crap, I did it wrong. I was supposed to wait like 4 years and then bump the thread asking if they were still available.
    edited March 2020
    Here. Fixed my sig to avoid confusion. :D
    Edit: WTF is the deal with the sigs being in such huge type anyways? That's just irritating as hell!
    Ah.
    tonyb Posts: 33,072
    Good choice....hard to replace for the coin.
  • Does anyone happen to know what the rocker switch on the back panel of the B&K Sonata monoblocks is for?
    F1nut Posts: 51,749
    I believe that is for switching between single ended or balanced.
    nooshinjohn Posts: 25,916
    audioluvr wrote: »
    You really need to get some tube power on those...
    Pretty happy with what I have currently. Though I do look, I'm saving for a Class A diesel pusher.
    Are these still for sale?
    edited June 2021
    You said you would wait 4 years! WTF?
