FXi5 mounting ques.
I have a set of FXi5 on speaker stands that are used for side surrounds. The stands are designed to have the speaker set on top of the main plate and i am using neoprene rubber feet that came with the stand to stabilize the speaker. I am concerned of the speaker being knocked off. I was thinking about using some double sided tape on the bottom of the speaker and attach it to the main plate. If i do this, will this damage the bottom of the speaker if one day i decide to take it off?
Also, is there any other recommendation that ya'll have to secure the speaker to the top plate such as velcro, etc.
Post edited by marcpam on
One of my FXi5's is on a narrow stand that holds DVD's and it has never moved.
http://clubpolk.polkaudio.com/showcase/closeup.php?userid=51750&pic=91_31_big.jpg -
is there anything holding the speaker there or is it just sitting on the dvd rack?
