alexa command tones on polk command bar
sorry for my stumbling english, but I dont find any solution or thread in this forum for my problem.
My problem is the volume of the command tones of the command bar if I using "Alexa". In the Alexa app, i can´t find the option to deactivate the tones for the bar. I only find this option by my echo or echo dot.
is´nt it possible to deactivate the tones in the command bar?
regards from germany
Toto
  • Toto
    Toto Posts: 3
    no answers no comments :'(
    F1nut Posts: 51,899
    I wish I could help you, but I know nothing about the problem you are having.
  • Toto
    Toto Posts: 3
    i think that not all features of alexa are included in this skill. that is annoying
    F1nut Posts: 51,899
    Alexa is annoying.
