Sda 2b transplantation into sda-crs+ boxes
JonathanPeterson
I have space issues and can't have giant speakers at the moment
I currently own crs+ bookshelves.
Picked up sda-2b on curb side . Were about to be thrown away during trash day.
Veneer looks new. Cabinets are great.
But I would like to build smaller boxes like sda crs+ maybe a little wider to accommodate 10" passive radiator.
From gimpod site looks like sda-crs+ and sda 2b are identical except for box size and passive radiator
I really don't need low end from these. Have 15" sub.
So
1) put drivers and tweeters into smaller box
2) replace mw6510 with mw6503(available from Polk directly)
3) recap crossovers and add that capacitor in parallel with that resistor to accommodate rdo-198 tweeter
What are Polk community thoughts on this
I appreciate and God bless usa
So
A couple folks here, including myself have converted M10's to SDA using CRS+ crossovers. I experimented on a 10B set and either the MW6502 or MW6511 needs to be in the SDA MW driver location since they are 4ohm nominal. The 6502's have better midrange, but the 6511's have better throw, thus better bottom-end frequency.
Search for member TennMan's post about his conversion. It's a simple affair.Don't take experimental gene therapies from known eugenicists. -
Are your CRS+ on stands now?Political Correctness'.........defined
President of Club Polk -
Sda-crs+ are on on two drawer cabinets
Ok, so taking up at least as much floor space as the better SDA 2B, yet you're wanting to make cabinets larger/wider than the CRS+!?! You also want to screw around with swapping drivers, crossover components and something about putting one SDA on top of another???
STOP the madness. Give the speakers to someone that isn't going to ruin them.
MW6502 or mw6511 are both 4 ohm and either can go in SDA driver spot for CRS+ crossovers.
MW6503 or mw6510 are 8 ohms nominal and work in the stereo circuit of CRS+ crossovers. Like you said, I found the 6502's tighter and better midrange production than the 6511's.
F1 means well, cause he's seen a lot of snowflakes smoke their equipment. He cares a lot.
JonathanPeterson wrote: »That's a conservative approach. I have yet to find someone who is better in carpentry and manual dexterity than I.
I like versatility of small speakers. U can put them anywhere. In NYC space is an issue.
How are sda-2b better?
I am not the guy who goes to the shop with lost eyeballs to get "serviced".
Need to back up your statements with some scientific evidence. I want more pronounced mid-range. Classical music , strings, guitar will definitely benefit from wider surface area of the sound source. Larger box makes more bass at the expense of mid-range clarity. If I am mistaken show me good evidence. I had 2 pairs of sda-crs+ stacked at some point. Good results. More volume and texture in piano, guitar. More impactful sound
Scientific evidence!?!......LOL
I'll tell you what, I'll give you the best there is, my ears. I owned both the CRS+ (with proper stands) and 2B. Both were fully modified including the TL mod. Hands down the 2BTL is better at balance, dynamics, presence, clarity, impact, tactical sensation, scale and ease of placement. I sold the CRS+ (4.1TL) and still have the 2BTL.
You may find this interesting. At first I modified the CRS+ and used the RD0194 tweeters. I didn't like the sound, so I did the TL mod and used the RD0198 tweeter, which resulted in a better presentation. Still not as good as the 2BTL though.
Just because two Polk MWxxxx drivers have the same ohm rating doesn't mean they are interchangeable. There are other extremely important specs.
TS parameters affecting low end response doesn't seem to be on his radar. Unfortunately as time wanes, and Polk no longer makes the various drivers, the swap meet here will become a thing.Don't take experimental gene therapies from known eugenicists.
JonathanPeterson wrote: »Well I'll give them a spin as is. Woofers inside don't have any stickers on them..hard to say if I have 2b with 6503 or 6510.
Crossover will tell you which sda 2 a or b you have. That there is not rocket science or are you referring to drivers? -
Use your technical skills instead of your carpentry skills to evaluate the speakers."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
How would he know difference between 6503 vs 6510 if only being able to ohm them out?Don't take experimental gene therapies from known eugenicists.
JonathanPeterson wrote: »Thanks for that suggestion. I am sure You sharp wit and sarcasm was highly appreciated here.will definitely use basic skills of electrician as opposed to dump truck drivers skills to try to figure out the drivers
Hey @JonathanPeterson welcome to CP! I do admire your desire to jump in and start making things happen. I do know that there is a lot of good advice here, and a lot of folks have traveled down the road before.
Congrats on the 2B's ! Wow what a find. I had a set of 2B's, of which I gave to a buddy, currently own a set of CRS's, and even though not modded, the 2B's IMO are a better foundation to begin your modification journey.
As a corollary, I was thinking a while ago to mod my 1st gen SRS's to a TL version, in order to run monoblocks, thinking it was just a matter of upgrading the electronics. But after chatting and receiving advice from members here, learned that it was more than just electronics and the drivers. The cabinets themselves are completely different on the inside. Sure you could do it, but the results? Probably not what I would have expected.
So I stood down on that project, and am keeping an eye out for the TL's!
Regardless, have fun! Glad you're here!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Well, no.
The CRS+ has an efficiency rating of 89.5dB.
The 2B has an efficiency rating of 89.7dB.Political Correctness'.........defined
I had found that after upgrading the XO in one of my RTA-11TL's it sounded louder than the unmodified even though they were the same part values. I think it was all perception. I should have used an SPL meter to verify.Stan
Main 2ch:
HT:
Other stuff:
Good luck!
