new cartridge any thoughts on a phono pre.
    Tony M Posts: 11,608
    edited January 2020
    I think I'll order the Hudson disc tonight. ;)
    200% was picked to see if the scale would go LARGER than the test line. It didn't.
    I couldn't get the test line up to 7.1" tonight. I tried 8 different things. It's CRAZY! :(
    Maybe I'll figure this PC out before I leave earth. :D
    I just ordered it from Amazon/from Hudson for 15.00 B)
    Thanks again guys. ;)
  • skrol
    skrol Posts: 3,442
    edited January 2020
    These are getting hard to find now but once you get the print scale right, print on a clear plastic view foil. They are less prone to temperature variation and don't swell with moisture. You can also make a dent or hole where the needle is to sit to hold it in place while you check alignment.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jbreezy5
    jbreezy5 Posts: 1,141
    This would be my pick in that price range (plus a couple of hundred) ;)
    https://www.goldnote.it/phono-stages/ph-10/
    Intriguing
