AC Infinity Aircom
Received my new AC Infinity Aircom cooling fans today to help keep my Outlaw amps a little cooler in my audio cabinet. My question is, what would be an ideal temp to set the thermostat on the units. Right now I have them set to 85 degrees but not sure if this is the correct temp or should I adjust. Thanks in advance.
    EndersShadow Posts: 17,713
    I’ve got mine in just the lowest fan setting for both my Denon X4100 and B&K 200.5
  • mrloren
    mrloren Posts: 2,473
    I have mine at auto, I think 85. Remember if it's turning on the top of you device is over 85 and hotter inside.
  • gyosa
    gyosa Posts: 770
    I have mine set at 86 in "smart" - eco mode ......
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
