Ampino with Salks
gyosa
Just in case anyone interested in this amp using various combinations....
Had time to try Verbs Ampino with
the Salk Super Charged Songtowers ....
Sounds great - fed Tidal hifi thru a Cambridge 851n ...
The Salks are 88db sensitivity....
Amazing little amp .....
Plenty of separation, nice highs and soundstage...
No complaints...
I think if you pair this amp with quality efficient speakers you will be pleasantly surprised ....
Was missing the LED power light ... naked wires were there - but no LED - emailed Dayens , they told me the replacement part number from Digikey .... ordered and I soldered in place ( 52 cent part - literally ) ... easy peasy ..... took care of the often mentioned “wobbly” volume knob with a layer of electrical tape on the shaft ... perfect now .....
Thanks again Verb !
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
Post edited by gyosa on
Awesome! Didn't even notice the LED was missing! And the volume knob fix, yeah characteristic of those amps - cool! Glad you're enjoying it!
Post some pics!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Bored tonite .....
Now feeding it an old pair of Boston Acoustics Voyagers .... new LED installed 😊
Spare iPhone 5 direct into it using 3.5 mm / rca adapter , tidal hifi ...
Sounds shockingly good .... you can’t have it back Verb 😊😂
Of course you can , if u want it ....
Seriously .... shockingly good ...
There’s something to be said for quality watts over quantity watts ....
Bk
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Lol @gysosa! I love that little Ampino! But not to worry, I have a spare!
Good to see the "adoptee" is getting great care."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
