Carver m1.5t
rebelsoul
rebelsoul Posts: 758
edited January 2020 in 2 Channel Audio
    pitdogg2 Posts: 27,236
    looks like a bank of transistors.
  • BlueFox
    BlueFox Posts: 15,250
    Looks like it is just sitting on the panel. Can you remove it?
  • rebelsoul
    Some one is selling this m1.5t at a good price thinking of buying it. I just have pics and this looks like the bottom of amp.
  • verb
    verb Posts: 10,176
    Interesting. Had a couple of M1.0t's back in the day. Never saw that mod before.
    rebelsoul wrote: »
    correct, and those 4 bolts with washers there look like the laminated power supply bolts that hold it down on the inside.
  • verb
    verb Posts: 10,176
    edited January 2020
  • verb
    verb Posts: 10,176
  • RobbyKY
    RobbyKY Posts: 117
    I have 2 different M1.5t's sitting unused at home.
    Can check and post pics of them tonight after my daughter's basketball game but I think I recall that's just by design on those.
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
    audioluvr Posts: 5,982
    RobbyKY wrote: »
    Hoarder!
  • rebelsoul
    Yes but this one is $275/300
  • rebelsoul
    Getting for a friend,I use to have 3
  • RobbyKY
    RobbyKY Posts: 117
    Hoarder!
    LOL. Wasn't sure if my wife had joined the site or not there....
    Here's a few of my stored Carver collection.
    Here's a bottom side view of an M1.0t vs M1.5t vs TFM-55
    The M1.5t is exactly the same as the previously pictured version. Forgot my son's been getting into playing around and swapped out a TMF-55 for my other M1.5t to check out the difference in sound. He says he's switching back to the TFM.
    Robby
  • daddyjt
    daddyjt Posts: 3,128
    verb wrote: »
    Those are the output transistors - five pair of TO-3 devices per channel. The 1.5t (as well as the 4.0t/45/42 Family and the silver 7t/9t) use the chassis as the heat sink - that’s why the output devices are mounted like that.
    ― Aleksandr Solzhenitsyn
    nooshinjohn Posts: 25,985
    I would like to check out a TFM-55 if you are up to parting with one.
  • RobbyKY
    RobbyKY Posts: 117
    Sorry, work was crazy yesterday. My son seems attached to the one that I've rebuilt. The pure stock one could be loaned out if you're anywhere near Dallas. I was using it full time before I bought my JC-5 and the only thing wrong is that it needs a recap due to age and the right channel can occasionally cut out due to the relay contacts. Cycling power fixes that. Got all the goodies to bring this into the modern world including gold RCA's and binding post so it's a future project.
