sub boxes
Systems
I had a momo a while back, but it fried when it blew the corners out of the box it was in being attached to a MTX 1000d as it overheated and the metal fused. I replaced it with a Infinity kappa perfect 12.... and in comparison, to say the least, you just cant compare them, the momo was above and beyond in both clarity and thump-ability. My question is, can i even get a box premade that would hold 1 or 2 momo 12's? and where? as i plan to loose the kappa perfect when i sell my car.
a now even more dedicated polk audio listener,
Russell
Russell
Testing
Testing
Testing
Testing
Testing
Russell,
To obtain the best performance from these woofers, we recommend building a enclosure out of 3/4" MDF. If you are
trying to locate a prefab enclosure, look at the enclosures from SubZone. Their toll free number is 800-377-7655 or their website address is ( www.subzoneusa.com ). If you purchase any prefab enclosure, seal all interior seams with a silicone caulking and install the gasket on the back of the mounting flange. You may also have to remove the carpet around the edge of the woofer opening to ensure a good air tight seal. To accommplish this use
a sharp razor knife.
If you need some assistance with enclosure recommendations,
installation, or wiring give us a call at 800-377-7655 between the
hours of 9 AM to 6 PM Eastern time and we will be glad to help.
Thanks,
Kim, Polk AudioTesting
Testing
Testing
