B1 Korg Preamp
Wardsweb
Having mentioned the B1 preamp in the "What did you do with your stereo today" thread, I thought I would post what it is. My latest build is based on a Nelson Pass design found on the DIYAudio forums. Even though it doesn't look like it, this is a tube preamplifier. What looks like a glass IC is actually a Korg Nutube 6P1 Dual Triode. I purchased the PCB and NuTube from DIYAudioStore. The mini "Pass Labs" chassis is from China.
I love the sound of this pre. It is dead quiet. The high end is crisp and clean. The mids smooth. The bass is tight. I get the "tubey" goodness without the high voltages and heat, as it runs on a 24v wall wart.
Great job! Beautiful.
Which one of your rigs do you currently have it running in?
This one is in the sun room.
Can you post a pic of the rear?
Thanks, appreciate it!
Nice creation. Always appreciate your work. Interesting volume control with all the resistors surrounding it.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
It is a stepped attenuator. Each level of output is regulated by a different resistance. -
Ah, didn't see it sitting on the plinth. I was trying to figure out what that was...This one is in the sun room.
My PSA BHK Pre is stepped. Never popped the hood far enough to look but assume it's a similar implementation. Other stepped vol's I've seen are enclosed with a metal cover and not so apparent. Cool looking. Saw the new Star Wars movie last night and yours could've been used as a death ray prop!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Your work makes me want to try and emulate it!
That rig is very simple and classy, and the size makes me think I want one in my work system lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Wow. That looks fantastic. Well done.
Curious, how much $$ (sans labor) do you have in it? -
The kit can be purchased at many levels from DIYaudiostore
The basic has the PCB and matched Jfets for $25. The Nutube is $50. The parts list for the PCB with power supply from Digikey runs around $25. You would need to source a chassis, wire, volume control and connectors.
The full blown turn key kit is $300.
My build is very different, in that I sourced a lot better parts for my PCB from Sonic Craft. It also means I had to do some modding to fit parts that were not made to fit the PCB. I already had wire, volume control and connectors. The chassis I got from China. I didn't track cost, but most likely total parts were more than the full blown kit but I have a next level pre over the stock kit. -
The stock kit looks like this. You can see mine is very different. That is the beauty of DIY, you can make it your own way.
It is very nice. Good high end without being shrill. Smooth mids and good bottom end. It is second only to my 6H30 custom build. -
neat-o.
In the days before Korg commercialized those things, there were crazy
hobbyists repurposing old VFDs as triodes... just because... they could.
Kinda gotta admire that spirit.
It's the kind of thing that makes guys (and they do tend to be guys) mount jet engines in the beds of their pickup trucks.
(and I do mean that as a compliment, at least to the VFD repurposers... not necessarily the P/U jet engine-ers, though)
Do you happen to have a link to the volume control and case you used?
I am very interested in replicating your work for a living room 2 channel rig with a single source...
Go to AliExpress.com and search 1506-PASS. There are many vendors selling this chassis. Look at both the price and the shipping cost together, to see which is the best price for you. Note it is made for an IEC connector. I had to make a block off plate to cover the hole, so I could install the DC input connector.
I don't have a link for the attenuator. It was something I got off Ebay 5 years ago. For plug and play, I would order an Alps RK27 in 50K or 100K. Always a great volume control. -
Here is my NuTube headphone amp build. Rechargeable battery powered.
CJ
A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
CJ
Nice! Love CAO flatheads too!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
What a CAO flathead?
Is that the same as this? Curious since this is a headphones piece.Here is my NuTube headphone amp build. Rechargeable battery powered.
https://www.head-fi.org/threads/portable-headphone-amp-kit-with-korg-nutube.892146/
I disabled signatures. -
Nope. I bought this board from Pete Millett.Is that the same as this? Curious since this is a headphones piece.
pmillett.com/nuhybrid.html
CJ
Hehe, turns out that head-fi thread cites Pete Millett as the kit source
I'm gonna look into this. That looks like a fun build.
CJ, for yours, am I correct in understanding that you have the little kit set up inside that cigar box?I disabled signatures. -
Yes sir. It's a pretty small board. I had room for a pair of batteries, the 1/8" trs audio in jack on the left side and the pot and 1/4" trs HD jack on the front.
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
Pete Millett is a wonderful resource to this hobby; roughly in the same league as Nelson Pass.
http://pmillett.com/
http://www.tubebooks.org/
One of the Pete Millett low-voltage space charge tube hybrid headphone amps I built some years back.
Now back to your regularly scheduled programming...
Nice full bodied sticks! Love em!
Hehe. I am dear sir, as @msg asked what the CAO Flatheads were. The bonus IMO is you get to smoke a bunch of excellent cigars then re-purpose the box. Wait, I may already have an empty box!
Scott help me out! Jimmy's got the long knives out!
