sl 3000 voice coil size
mikeymike48
anybody know the voicecoil size on the sl 3000 tweeters, I think they are either 25.5 mm or 26 mm, also can I use an 8 ohm replacement vc, the tweets I believe are 6 ohm.thanks
Answers
Bin the SL3000. The RD0198 is a better tweeter.Political Correctness'.........defined
President of Club Polk -
thanks for your response, ive actually ordered 2 198s, I just wanted to see if I could fix the 2 sl 3000s and 1, 2500 that are toast
