B1 Korg Preamp
Having mentioned the B1 preamp in the "What did you do with your stereo today" thread, I thought I would post what it is. My latest build is based on a Nelson Pass design found on the DIYAudio forums. Even though it doesn't look like it, this is a tube preamplifier. What looks like a glass IC is actually a Korg Nutube 6P1 Dual Triode. I purchased the PCB and NuTube from DIYAudioStore. The mini "Pass Labs" chassis is from China.
I love the sound of this pre. It is dead quiet. The high end is crisp and clean. The mids smooth. The bass is tight. I get the "tubey" goodness without the high voltages and heat, as it runs on a 24v wall wart.
  • Conradicles
    Conradicles Posts: 6,407
    Great job! Beautiful.
    treitz3 Posts: 20,253
    Which one of your rigs do you currently have it running in?
  • Wardsweb
    Wardsweb Posts: 943
    treitz3 wrote: »
    This one is in the sun room.
    Clipdat Posts: 13,101
    Can you post a pic of the rear?
  • Wardsweb
    Wardsweb Posts: 943
    Clipdat wrote: »
    Thanks, appreciate it!
  • JayCee
    JayCee Posts: 1,509
    Nice creation. Always appreciate your work. Interesting volume control with all the resistors surrounding it.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Wardsweb
    Wardsweb Posts: 943
    JayCee wrote: »
    It is a stepped attenuator. Each level of output is regulated by a different resistance.
    Wardsweb wrote: »
    Ah, didn't see it sitting on the plinth. I was trying to figure out what that was...
  • JayCee
    JayCee Posts: 1,509
    Wardsweb wrote: »
    JayCee wrote: »
    My PSA BHK Pre is stepped. Never popped the hood far enough to look but assume it's a similar implementation. Other stepped vol's I've seen are enclosed with a metal cover and not so apparent. Cool looking. Saw the new Star Wars movie last night and yours could've been used as a death ray prop!
    EndersShadow Posts: 17,747
    Your work makes me want to try and emulate it!
    That rig is very simple and classy, and the size makes me think I want one in my work system lol....
  • joecoulson
    joecoulson Posts: 4,963
    Wow. That looks fantastic. Well done.
    Curious, how much $$ (sans labor) do you have in it?
  • Wardsweb
    Wardsweb Posts: 943
    The kit can be purchased at many levels from DIYaudiostore
    The basic has the PCB and matched Jfets for $25. The Nutube is $50. The parts list for the PCB with power supply from Digikey runs around $25. You would need to source a chassis, wire, volume control and connectors.
    The full blown turn key kit is $300.
    My build is very different, in that I sourced a lot better parts for my PCB from Sonic Craft. It also means I had to do some modding to fit parts that were not made to fit the PCB. I already had wire, volume control and connectors. The chassis I got from China. I didn't track cost, but most likely total parts were more than the full blown kit but I have a next level pre over the stock kit.
  • Wardsweb
    Wardsweb Posts: 943
    The stock kit looks like this. You can see mine is very different. That is the beauty of DIY, you can make it your own way.
  • Wardsweb
    Wardsweb Posts: 943
    mhardy6647 Posts: 35,480
    ahh, the Korg VFD "NuTube" :)
    https://korgnutube.com/en/
    How do you like the sound of it?
  • Wardsweb
    Wardsweb Posts: 943
    It is very nice. Good high end without being shrill. Smooth mids and good bottom end. It is second only to my 6H30 custom build.
    edited December 2019
    neat-o.
    In the days before Korg commercialized those things, there were crazy ;) hobbyists repurposing old VFDs as triodes... just because... they could.
    Kinda gotta admire that spirit. :)
    It's the kind of thing that makes guys (and they do tend to be guys) mount jet engines in the beds of their pickup trucks.
    B)
    (and I do mean that as a compliment, at least to the VFD repurposers... not necessarily the P/U jet engine-ers, though)
  • Wardsweb
    Wardsweb Posts: 943
    ZLTFUL wrote: »
    Do you happen to have a link to the volume control and case you used?
    I am very interested in replicating your work for a living room 2 channel rig with a single source...
    Go to AliExpress.com and search 1506-PASS. There are many vendors selling this chassis. Look at both the price and the shipping cost together, to see which is the best price for you. Note it is made for an IEC connector. I had to make a block off plate to cover the hole, so I could install the DC input connector.
    I don't have a link for the attenuator. It was something I got off Ebay 5 years ago. For plug and play, I would order an Alps RK27 in 50K or 100K. Always a great volume control.
  • CoolJazz
    CoolJazz Posts: 572
    Here is my NuTube headphone amp build. Rechargeable battery powered.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • verb
    verb Posts: 10,176
    CoolJazz wrote: »
    CJ
    Nice! Love CAO flatheads too! :smile:
    msg Posts: 10,609
    edited January 2020
    What a CAO flathead?
    CoolJazz wrote: »
    Is that the same as this? Curious since this is a headphones piece.
    https://www.head-fi.org/threads/portable-headphone-amp-kit-with-korg-nutube.892146/
  • CoolJazz
    CoolJazz Posts: 572
    msg wrote: »
    Nope. I bought this board from Pete Millett.
    pmillett.com/nuhybrid.html
    CJ
    msg Posts: 10,609
    Hehe, turns out that head-fi thread cites Pete Millett as the kit source :)
    I'm gonna look into this. That looks like a fun build.
    CJ, for yours, am I correct in understanding that you have the little kit set up inside that cigar box?
  • CoolJazz
    CoolJazz Posts: 572
    msg wrote: »
    Yes sir. It's a pretty small board. I had room for a pair of batteries, the 1/8" trs audio in jack on the left side and the pot and 1/4" trs HD jack on the front.
    CJ
    edited January 2020
    Pete Millett is a wonderful resource to this hobby; roughly in the same league as Nelson Pass.
    http://pmillett.com/
    http://www.tubebooks.org/
    One of the Pete Millett low-voltage space charge tube hybrid headphone amps I built some years back.
    Now back to your regularly scheduled programming...
  • verb
    verb Posts: 10,176
    Nice full bodied sticks! Love em! :smile:
    Viking64 Posts: 7,753
    verb wrote: »
    STAY ON TOPIC!!!!!!!!!!!!! :s
  • verb
    verb Posts: 10,176
    edited January 2020
    Hehe. I am dear sir, as @msg asked what the CAO Flatheads were. The bonus IMO is you get to smoke a bunch of excellent cigars then re-purpose the box. Wait, I may already have an empty box! :smile:
    Scott help me out! Jimmy's got the long knives out! :smile:
