Denon 3500h or Yamaha TSR 7850
Hi
Costco is doing a nice discount on the Yamaha TSR-7850.......but it only has 2 pre-out
The Denon 3500h is $550 on Amazon, with full set of preouts and XT32 (and I have a $150 gift card)
Nonetheless, is the Denon a higher level receiver than the Yamaha?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
  • rooftop59
    rooftop59 Posts: 8,120
    Denon ftw. For the reasons you list. And those avr-x models sound great for HT and not too shabby at all for music...
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,473
    +1 for Denon
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited December 2019
    Yes, that Denon is a higher level receiver than that Yamaha. Compare the Denon AVR-X series to the Yamaha AVENTAGE series (both are very good), but if these are the two models you're down to, as others recommended, go with the Denon.
  • Amazon has the Yamaha TSR-7810 Refurbish with a one-year warranty for 299.00 unit has pre-amp out for all channels.
  • deronb1
    deronb1 Posts: 5,021
    Muchieman wrote: »
    I have this unit. Very happy with it.
  • deronb1
    The app for the Yammy works great.
  • deronb1 wrote: »
    Muchieman wrote: »
    I have TSR-7790, got it off of A4L over two years ago still going strong! It’s 95 x 2 into 8 ohms. Doesn’t have DTS-X or Atmos, has everything else. Unit has been really good. Love the 4K up convert, Since I’m in a small apt, really can’t do Atmos. Plus Going to a newer unit wouldn’t give me much if any improvement. I will add two Outlaw monoblocks next month. Don’t really need them just want them 😁
  • deronb1
    All good. I have a B&K 5 ch amp hooked up ro it. If I had one small beef, is that the output of the preouts coukd be a bit more. Even with the input settings at +6 still need to up the volume.
  • deronb1 wrote: »
    yep, Gene over on AH had done some test on Yamaha A870 he found that that out put was low on that unit also. It should be a Standard on All unit’s that have pre-amp outs of 2.0v.
  • deronb1
