Linbrook Signature Monitor Review
phipiper10
phipiper10 Posts: 961
edited May 2007 in Speakers
I know you've all been holding your breath but I recently had a little time so here is my review of the Tyler Linbrook Signature Monitors. As I’ve said before my audio experience in terms of trying lots of different gear is relatively limited so forgive me.
I’ve had the RT800i for 4/5 years and recently had the Lsi15 for a few weeks. The rest of the set up can be seen below. I’ve had a couple of sessions with the Focal 836v and Dynaudio Focus 220 too.
I probably say this every time I make an upgrade and it’s the same thing I see when I see other people’s reviews of their upgrades; more vibrant, more lifelike and more detailed. Also better imaging and soundstage…..blah, blah. OK, all of that is true relative to speakers I mentioned above.
Here is what I found special about these speakers. They put everything on display. By this I mean when 3 and 4 instruments converge at one point in time a lot of times speakers just produce a sound that is a combination of the instruments being heard. With these I was still hearing each instruments and not just a single sound created by the combination of the individual sounds. I could still concentrate on each instrument, everything was “accessible”. Making the collision of sounds more meaningful and interesting.
I think some of these secondary and tertiary sounds - background guitars or keyboards or cymbals are much more “available”. Definitely not forward in an artificial way as the balance of where the sound is coming and it's presence seems natural in terms of imaging and the relationship between each instrument.
The more comparitive part:
I think I’m becoming more aware of how different speakers handle different types of music. Some might be better for a particular type of music. Depending on the tracks there might have been very little difference to what I’d say is a considerable difference between the Lsis and the Tylers all depending on the track. Even where differences were subtle each speaker still had it’s “signature” sound.
Tracks where vocals were the feature I played my usual Jerry Garcia and Sara Mclauchlan tracks. In both cases I felt the singers were closer with the Tylers than the Polks.
On a couple of different Wilco tracks with more sparse sounds and background noises I found more “space” and “air”, though I wouldn’t necessarily say these are general characteristics or traits of these speakers. (I might consider the 836v a bit “airy”) I don’t consider the Tyler’s “airy”. The imaging and soundstage was most definitely improved compared to the Polks on these tracks and less so on others.
I think I can say the Tyler’s are more revealing but also, and separately, you could technically say “brighter”, though they are not bright. But when comparing to the Lsis most anything is brighter, right?. The Polks just seemed to make me work a bit harder to hear some of the detail. I still heard the details but I felt I was a little challenged to hear what I was hearing from the Tylers. The Polks made me feel like I should move closer in an effort to hear more of what was going on, those background effects I mentioned- guitar, keys, cymbals and other odd sounds. They were all there but they just didn’t provide the same affect as with the Tylers.
The Tylers are as smooth or almost as smooth as the Polks but because they are more revealing I don’t think smooth comes to mind as an adjective for the Tylers. I think the “smooth” comes at a price in this case and that price is detail. As for the bass of the Tylers it’s what you’ve probably heard, tight and punchy and that’s no joke. Even before the Tyler’s appeared, the bass from the Polks was just good but nothing beyond that, IMO. I love my HSU STF-2 so the down low is handled when necessary but I usually don’t have this on during two channel listening.
I’m very pleased with them at the price I paid. Comparing the Tylers at full price to a pair of used Lsi at $750 or so I’d go with the Polks in a second. If you can get the Tyler’s at $1500 or so seems worth it to me or even a Tyler monthly special for $2k (shocking right!). Again I’m not an expert but I feel I must be getting close to my personal point of diminishing return, at least for speakers.
I’ll also say that I believe there is a LOT more potential in these speakers but I’m limited by the room, my living room, with a 42” TV and a 5’ audio rack between the speakers I know I’m missing out. Two cast iron radiators with tin shields opposite the speakers and 6 really old windows to the side can’t be helping either. The rear wall is only 10-12 ‘ opposite the speakers and most of the walls are bare with the exception of a few pictures and a small shelf.
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • brijenjas
    brijenjas Posts: 311
    edited May 2007
    Great review,very articulate. I have a lot of trouble trying to put into words what I'm hearing with audio gear.
    The Linbrook Sigs are definitely a speaker I would like to own one day on my audio journey.
    VR3 Posts: 29,497
    edited May 2007
    The nailed it man.
    Definition, clarity, depth and precision. The Tylers do it all.
  • fatchowmein
    fatchowmein Posts: 2,637
    edited May 2007
    Awesome review. Very informative. I liked how you gave an individual description followed by a comparative review along with a dollar figure. For me, the ultimate test comes when I'm listening to Diana Krall sing "Besame Mucho". If I close my eyes, would I be able to reach out and grab her arse? Can I do so at a lower dollar amount?
    Disclaimer: The prior statements are meant as an example of a speaker's ability to create realism and is not intended to offend Elvis Costello. Any and all similarities between my imagination and the real-life Mrs. Diana Costello is purely coincidental.
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    Amazing review. Shows how room acoustics play into the midst of things too - which is probably the most important influence on the sound.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Nice review.
    engtaz
  • haimoc
    haimoc Posts: 1,031
    edited May 2007
    Very nice review. I guess I'd be tylerized, someday..
  • G-2
    G-2 Posts: 533
    edited May 2007
    Nice job!! Thanks!
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited May 2007
    Very well put! I imagine those speakers will continue to reward you down the road.
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Once you change out the pre, you'll really begin to hear just how good those speakers are.
    "God grooves with tubes."
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited May 2007
    He had me at "tertiary."
  • mldennison
    mldennison Posts: 307
    edited May 2007
    very nice review, thanks! you mentioned that you have had some time with the dynaudio focus 220's. would you care to compare the two?
  • phipiper10
    edited May 2007
    The focus 220 was some time ago now but I did review them previously..
    http://www.polkaudio.com/forums/showthread.php?t=49123&highlight=focus+220
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    Very nice review.
  • Just came across my own review in a search....For the record everything in my rig has changed since this review except the Tylers. I don't believe they are outmatched relative to the rest of the gear.
    Next move is likely to be a preamp upgrade.
  • erniejade
    erniejade Posts: 6,321
    If you are still running the Rogue, that is a solid pre as it is!
