MagniFi One and home computer hookup
Loadie
Hello,
I just had a Mangifi one sub system given to me and I was wondering if you could hook this up to a home computer? I’ve looked but can’t find anything on how to do it, or if it’s even possible?
Going by a quick look at the product page, it's got optical input and 3.5mm input. You could get a cable with 3.5mm stereo connectors on each end.
Plug one end into the headphone jack/line out jack on your computer, and the other end into the MagniFi. That should get you going.
https://www.polkaudio.com/products/magnifi-oneI disabled signatures.
