Polk CRS+ front trim piece
How is that connected to the main cabinet? Is it possible to remove and reinstall easily?
Thank you.
    F1nut Posts: 51,934
    Some are simply butt glued on, others have small dowels and glue.
    gudnoyez Posts: 8,172
    I sold a second pair a of these I had a while back and the trim piece was loose I replaced the dowel pieces in them and reglued them.
