Rotel RB-1590 or Parasound A21+?
BjornB17
BjornB17 Posts: 752
edited December 2019 in 2 Channel Audio
I have the opportunity to acquire either of these two amps to power a pair of RTiA9's (also supported by pair of Rythmik F18's). From what I can tell, both of these amps are smooth, sweet, and slightly warm of neutral which should go well with the A9's. Is either of them a clear choice over the other? Functionally the Rotel works a little better since the shape fits better into my furniture but can make the Parasound work as well. I'm thinking either will be almost equally good but I'm still stuck between the two. This will be in a fairly big room (26'x18'x11'), mostly home theater but a bit of music and general media streaming as well.
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • I had A21 that drove RTiA9s and I enjoyed it. Even better if you can get something that delivers even higher watts. Clarity/details goes up with more juice...
    pitdogg2 Posts: 27,335
    Parasound will have better woofer control. It is a better amp IMO
  • Upstatemax
    Upstatemax Posts: 2,802
    I find the Rotel amp to be warmer and more musical.
    Great control of the soundstage and plenty of woofer control. I just find the A series parasound amps to be a bit sterile.
    The RB 1582 MKII has been handling my Venere S speakers wonderfully. The 1590 I heard was fantastic.
    I was contemplating buying one myself, but they announced the Michi line. Now I’m dying to get my ears on those amps!
  • BjornB17
    BjornB17 Posts: 752
    haha, great feedback - sounds like people are split on which is better. The warm+musical combo sounds good to me. I would likely be wanting the black version of either.
    gudnoyez Posts: 8,174
    I find my A31 Halo a perfect match powering my A9s and CSI A6, however that Rotel is probably very capable also. Let us know what you end up getting.
  • gyosa
    gyosa Posts: 770
    I vote for Parasound ....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    audioluvr Posts: 5,989
    I vote for the Rotel
  • jdjohn
    jdjohn Posts: 3,384
    If the opportunity is local, maybe you could audition both, and then decide.
  • mpitogo
    mpitogo Posts: 520
    I have the Rotel RB-1590 and recently put it back into service repurposed as amps for the front left/right in my HT. I don't have experience with Parasound and can't compare but I can say the Rotel is a very nice capable piece.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • Emlyn
    Emlyn Posts: 4,827
    The A21+ will be more refined and smooth sounding, the 1590 more powerful but also grainier. I would pick the A21+ for two channel but the 1590 for home theater, or the smaller 1582 may be a better choice. The RTi speakers are not tough loads to drive.
    If using an entry level AV preamp to run into the amp the choice of amp is not all that important really. But either amp can be around for a long time as the rest of the system grows around it.
  • BjornB17
    BjornB17 Posts: 752
    Since the A21+ is a little too long, what about getting a pair of A23+ and running them each in bridge monoblock mode? 500 wpc when bridged!
    F1nut Posts: 52,009
    BjornB17 wrote: »
    Bridged amps have a higher noise floor.
    I agree with Emlyn that the Rotel amps are grainy.
  • BjornB17
    BjornB17 Posts: 752
    BjornB17 wrote: »
    I just heard back from Parasound and they confirmed the higher noise floor and that THD doubles when bridging.
    Maybe I should just roll with the A21+, it is a little long but I can work with it. Also costs a little less than the Rotel.
  • Emlyn
    Emlyn Posts: 4,827
    If you are buying new, Audio Advisor has the A21+ on sale now.
    If you are looking to primarily do home theater with an amp, the A31 in its "legacy" finish is a great deal while they last...I just got one myself. Gives all three front speakers the same amplification.
    https://www.audioadvisor.com/prodinfo.asp?number=PAHA31
  • HzTweaker
    HzTweaker Posts: 1,041
    I vote A21+ :)
  • CH46E
    CH46E Posts: 3,595
    While I have only had a Parasound HCA750A and a Parasound 2250 v2 (Never a Halo)and have only worked at a place that sold Rotel, I think I'd go for the Rotel. But that might just be because I have owned Parasound and not Rotel. I always really liked what the Rotels sounded like in the showroom.
    No matter what way you go, I think you will enjoy.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    BjornB17 wrote: »
    There isn't much out there that is Sexier than a Black Halo piece of gear.
  • Upstatemax
    Are you basing this opinion on the RB 1590 and RB 1582 MKII specifically?
    Because my own hands on experience with them has shown the exact opposite.
    With the Rotel amps in, soundstage was wider, better midrange clarity and warmer.
    With the A21 we noticed the midrange shrink and push back, soundstage shrink and a top end glare.
    I don’t think a single person in that room would have called the Rotel amps grainy.
    I bring this up because I know Rotel amps in the past suffered from what you’re describing, but I feel that the current crop are a whole different animal.
  • Dr_Wu
    Dr_Wu Posts: 356
    I've had both Rotel (RB990BX) and Parasound (A21) for 2-channel. Liked them both. Like the Halo better. But, it IS a beast.
    Now that we've totally confused the OP. Do you have a quarter? Flip it. Heads for Parasound, tails for Rotel. Problem solved. :D
  • CH46E
    CH46E Posts: 3,595
    I could see the Class D Rotels being considered grainy by some. But that 1590 is a Class AB amp and should be superb.
  • BjornB17
    BjornB17 Posts: 752
    Well now I am thoroughly confused :D
  • Upstatemax
    Your best bet is to try and get your ears on both and figure out what amp works better for you.
  • CH46E
    CH46E Posts: 3,595
    My next amp purchase will likely be a Rotel. It's just what's next in my line.
    I'll throw this in the mix of confusion:
    https://www.usaudiomart.com/details/649576017-bampk-sonata-pro-10-preamplifier-and-m-200-200wpc-monoblock-amplifiers/
    These rarely come up for sale. I'm having my restored to the tune of over $1,000. Wouldn't cough up this kind of money unless I liked them. The Pro 10 is extremely rare. One of the best solid state pre amps made and mate perfectly with the amps.
