roon V.17 Valence
Garage | Polk Monitor 5B's
  • GlennDog
    GlennDog Posts: 3,149
    edited November 2019
    I’ve been thinking of diving into Roon. Just using the Lumin app now. Think this might prompt me ...
    How you liking it?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Mikey081057
    Mikey081057 Posts: 7,127
    I signed up for the lifetime sub after using it for 1 year and integrated all of my devices into it so now I only use 1 app across all. It is great for that. I never got used to the Lumin app so I can't really compare but didn't see any sense in it even tho many seem to think it's the schizzle. roon radio has improved over the past couple of years and the notes say there is a significant upgrade in this release so I will give it a try.
    You can always do the free trial and see... If it is something you use frequently you will be able to make a determination pretty quickly.
